Helldivers 2 Speargun Guide (2025 Update)
  • ThunderNova
    Auto posseduta: ct25
    da ThunderNova » venerdì 7 novembre 2025, 8:04
    With the Helldivers 2 Speargun Damage & Guide (2025 Update), Arrowhead has made several adjustments to one of the most divisive support weapons in the game—the Spear. Whether you love its high-risk, high-reward design or hate its unpredictable lock-on behavior, the Speargun remains a powerful anti-armor option that rewards precision and patience. This updated guide covers its latest stats, effective use cases, and how to make the most of it in 2025.
    Speargun Overview
    The Speargun is a support weapon that fires guided anti-tank projectiles, designed to destroy armored targets such as Automatons and Terminid Chargers. While its reload and lock-on mechanics can feel clunky, the weapon’s raw damage potential makes it a solid choice for players who prefer long-range armor removal.
    After the latest balance patch, the Speargun’s damage has been slightly re-tuned. While it doesn’t one-shot heavy units as reliably as before, its consistency and lock-on accuracy have improved. The weapon now locks onto large enemies faster and is less likely to miss when aiming from a higher elevation.
    Speargun Damage Breakdown
    Post-update, the Helldivers 2 Speargun Damage & Guide (2025 Update) confirms that the weapon delivers around 6,000–7,000 armor-piercing damage per hit, depending on range and impact angle. This makes it one of the few tools capable of reliably destroying Automaton Tanks and Chargers without requiring a team effort.
    However, the damage is heavily dependent on direct hits. Splash damage remains minimal, so positioning and aim are key. Missing a shot can be costly, as the reload time sits around 6 seconds, leaving you vulnerable if you’re not behind cover or supported by teammates.
    How to Use the Speargun Effectively
    Use Lock-On Wisely – Hold aim until the lock-on icon flashes solid before firing. Partial locks often result in misses.
    Stay at Range – The Speargun excels at long-range combat. Avoid close engagements where reloads and aiming become cumbersome.
    Pair with Spotters or Scanners – Having a teammate mark armored targets can help you secure faster locks.
    Know Your Targets – It’s best against large enemies—Tanks, Hulks, Chargers, and Bile Titans. Using it on small bugs or infantry is a waste of ammo.
    Positioning Is Everything – Take advantage of high ground or open fields. The missile’s arc is less predictable in dense environments.
    Loadout Recommendations
    To maximize your Speargun’s performance, combine it with gear that complements long-range and defensive play:
    Primary Weapon: AR-23 Liberator or SG-225 Breaker (for close encounters).
    Secondary Weapon: Pistol or SMG for emergency use.
    Stratagems: Shield Generator Relay, Supply Pack, or Orbital Precision Strike for area control.
    Armor Passive: Engineering Kit or Fortified to improve survivability during reloads.
    Is the Speargun Worth Using in 2025?
    The 2025 patch has made the Speargun more reliable without removing its signature quirks. It’s no longer a weapon for casual use—it demands patience and skill—but in the hands of an experienced player, it remains one of the best tools for deleting high-value targets from a safe distance.
    In short, if you enjoy a methodical, precision-based playstyle, the Speargun is still a strong pick in Helldivers 2.
    The Helldivers 2 Speargun Damage & Guide (2025 Update) highlights that this weapon, though not the easiest to handle, rewards strategic play and coordination. The rebalanced damage and improved lock-on mechanics make it a more viable choice in higher-difficulty missions. Mastering it may take time, but few things are more satisfying than watching an Automaton Tank explode from across the battlefield with a perfectly timed shot.
