Codice: Seleziona tutto
Thursday,22,August,2019,14:53:17:39744
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000 License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 0B
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210224E3217100B5842524E484D700401300
Shop #: WSC 00788 648 00255
VCID: 00085B4297984341E9-8054
No fault code found.
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397EF6A6B0C2D289EE-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 060161479
Coding: 3CB02BBF08E1240092380E916C6B0DD1DAC0672F608D30D0200000030000
Shop #: WSC 02737 534 00190
VCID: 68D863E29BE89B0141-803C
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU004011200011991
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU005011200017885
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Coding: 000000
Subsystem 5 - Part No: 1K8 951 171 A
Coding: 000000
Subsystem 6 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H04 0103
Serial number: 29170002240760027504
Coding: A40000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU010011200012406
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU009011200013136
Coding: 08BC32
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 146
Mileage: 95139 km
Time Indication: 0
Date: 2020.14.20
Time: 14:49:17
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 20251528901029
Coding: 100001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParaKssis4K 001004
ROD: N/A
VCID: 3A7CE9AABDC4D991E7-806E
No ASAM data for: "EV_VW75XParaKssis4K" (VW25)
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX011W0JJ
Coding: 003232
ASAM Dataset: EV_AirbaVW10BPAWV250 A01001
ROD: N/A
VCID: 4A9CB96AED24491177-801E
Subsystem 1 - Serial number: 3575HRB4059124B2F99H
Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaVW10BPAWV250" (VW25)
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 871 A HW: 6R0 920 871 A
Component: KOMBI H03 0505
Serial number: 00000000000000
Coding: 140E01
ASAM Dataset: EV_KombiU_DS_VDD_RM09 A04113
ROD: N/A
VCID: 3460C7929FA02FE13D-8060
No ASAM data for: "EV_KombiU_DS_VDD_RM09" (VW36 *)
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 002200
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0505
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADC19EA8DE4A91157-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0110000001000000
ASAM Dataset: EV_HealdRegulVWLWRPt 001004
ROD: N/A
VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HealdRegulVWLWRPt" (VW25)
Address 56: Radio (J503) Labels: None
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5314
Revision: -------- Serial number: VWZZZ4K6200530
Coding: 16000400040005
Shop #: WSC 127395 840 08317
VCID: 46848D5AF13CAD7193-8012
End-------------------------(Elapsed Time: 03:21)--------------------------
