POLO 6R 1.2 TSI 90CV R-LINE BIANCO 5p.
    ciclo
    Auto posseduta: 1.2 TSI R-Line
    Re: POLO 6R 1.2 TSI 90CV R-LINE BIANCO 5p.
    da ciclo » giovedì 8 maggio 2014, 6:33
    Yes, is the same electrical installation. Do not apologize, ask anything you need to know.
    I recommend you take the electric supply of the fuse box (less wires in the drawer radio). A 5 Amp fuse is good.
    Must be positive continuous +30. No +15 after ignition.
    I see that it has changed the format of the forum. :023
    da claudio-dj » giovedì 8 maggio 2014, 7:45
    So with only positive arrival in the fuse box and not to the radio?
    We are renewing some forum! :047
    ciclo
    da ciclo » giovedì 8 maggio 2014, 7:59
    Yes :023
    Ultima modifica di ciclo il lunedì 16 giugno 2014, 22:38, modificato 1 volta in totale.
    da claudio-dj » venerdì 9 maggio 2014, 12:28
    But then you have connected to the positive terminal of the rear view camera, the fuse of the controller in the instrument cluster?
    Because to me that the fuse is already present! :017
    ciclo
    da ciclo » venerdì 9 maggio 2014, 13:01
    In my r-line that slot was empty. Inside the fuse box is a metal strip which supplies many fuses in that area, from SB20 to SB53.
    It comes from SA3 (110amp) direct from the battery..
    I put a fuse of 30amp and subdivided it for various retrofitting. :045
    Original fuse box.
    da claudio-dj » venerdì 9 maggio 2014, 13:25
    Could you also tell me the codes of the terminals to be used in the fuse box?
    But if I want to connect behind the radio, I use pin 16 or 15?
    ciclo
    da ciclo » venerdì 9 maggio 2014, 16:14
    edit...
    Jay-Jay
    da Jay-Jay » sabato 10 maggio 2014, 0:01
    Hi Ciclo,
    have you ever checked what is the highest boost of your turbo?
    Mine doesn't go over 1,1 bar (via OBD2 Bluetooth with Torque app on Android) :017
    da claudio-dj » sabato 10 maggio 2014, 9:18
    Ok ciclo... I respected your fuse box whit one 30a fuse in the Sb49 slot...and i have connected this fuse at the slot empty whit 5A fuse for rvc...but i have a problem...the module pdc don't take a long coding!!! Message vag : Error 31... Do you know?
    ciclo
    da ciclo » sabato 10 maggio 2014, 18:31
    claudio-dj, if you code exactly as at the end of this tutorial, everything works correctly. :023
    https://docs.google.com/document/d/1xZF ... edit?pli=1
    You need to activate the access code. :019
    Jay-Jay ha scritto:Hi Ciclo,
    No, I've never checked. I'll check. :006
    da claudio-dj » sabato 10 maggio 2014, 19:26
    But one thing I do not understand ... the fuse 5a of the rvc I also feed the pin16? or 5A fuse is in series with the connection to pin16? :012
    I activated the code! :016
    I noticed that the PDC control unit is not for POLO, but for GOLF.
    Could this be the problem?
    ciclo
    da ciclo » sabato 10 maggio 2014, 20:25
    RVC---->Fuse 5 amp----->pin 16. Easy.
    Yes, that's the problem, you have to code your unit exactly like golf. Search Golf Forum.
    The BCM, navigator or radio as in the tutorial. :023
