POLO 6R 1.2 TSI 90CV R-LINE BIANCO 5p.
    ciclo
    Auto posseduta: 1.2 TSI R-Line
    Re: POLO 6R 1.2 TSI 90CV R-LINE BIANCO 5p.
    da ciclo » domenica 27 aprile 2014, 4:44
    edit...
    Ultima modifica di ciclo il domenica 15 giugno 2014, 0:22, modificato 1 volta in totale.
    lacky8487
    Auto posseduta: Polo 6r R-Line Dsg
    nome: Luca
    da lacky8487 » domenica 27 aprile 2014, 10:11
    :023 Cycle hello, have you installed the LED in the fog?
    I ordered the directional lights 'MTEC h7 super white' recommended by you!
    [/color]Polo 6R 1.6 Tdi 90cv R-line Dsg
    Interior pack R-line, tech&sound pack, comfort pack,luci led vano piedi lunotto e parasole, battitacco logo R-line, cielo di colore nero oem, sterzo multifunzione DSG Black Edition cuciture grigie, portaocchiali black edition
    Exterior pack R-line,vetri oscurati,fari Bi-Xeno adattivi con luci diurni a LED oem,tetto panoramico, cerchi in lega “Mallory” da 16,luci targa led oem
    My polo R-line : viewtopic.php?f=59&t=24132
    ciclo
    da ciclo » domenica 27 aprile 2014, 10:31
    No. I'm waiting for the LED 2400 lumens.
    I guess that in three weeks I'll have installed. :023
    da claudio-dj » lunedì 28 aprile 2014, 23:46
    ciclo ha scritto:The problem is not the light sensor for those with halogen headlights.
    The main problems without much thought are :
    1 - Keep in mind that the BCM has available PIN 37 and 1 in slot A (you check it).
    2 - One or two more relays would be needed for side lights and rear fog. For 5ND 941 431 B XSH or 3C8 941 431 A XSH
         Depends VW POLO with or without start/stop system. Or that lights are controlled by the BCM
    3 - That the setting of the headlights in the BCM was correct. This is the biggest handicap. Perhaps the Hexadecimal is well established, but if no, what would it be?
    If you have Elsawin you can look at the electric light switch diagram of SEAT Ibiza 6J 2011> with halogen headlights
    For the coming/leaving home using this relay:
    What is the reference number of your BCM? :017
    PS: if I had a polo with light sensor and halogen headlights would already be done. :064 ... :005
    Edition:
    I just reviewed the schemes for VW POLO 6R with halogen headlights, light sensor and start/stop system, and my wiring should also work.
    Considering that the settings in the BCM for headlight are correct. BCM required: 7H0 937 090
    :017 BlueGT with halogen headlights.
    I need two images of the light switch connector on both sides in HQ. That can see the numbers and wire colors.
    say that I did not understand that much! :009
    however my BCM is a 937-087..... tell me what you can do please!! :022
    Because I've seen cars with automatic headlights and light sensor despite the low beam.
    And since my unit manages the brightness of the interior lights and the navigator from the sensor, it seemed feasible, perhaps with suitable relays, even changing the automatic lights. :017
    because you wanted a car without bi-xenon to try, we can do even if you want to change car! :044
    ciclo
    da ciclo » martedì 29 aprile 2014, 5:11
    edit...
    Ultima modifica di ciclo il lunedì 16 giugno 2014, 22:35, modificato 1 volta in totale.
    ciclo
    da ciclo » sabato 3 maggio 2014, 16:06
    edit...
    ciclo
    da ciclo » lunedì 5 maggio 2014, 17:22
    Received my new goodies.
    To be continued. :003
    Ultima modifica di ciclo il lunedì 16 giugno 2014, 22:36, modificato 1 volta in totale.
    da bonzo86 » lunedì 5 maggio 2014, 19:29
    very nice, looking forward to the mounting
    da claudio-dj » lunedì 5 maggio 2014, 21:45
    ciclo ha scritto:Your first problem is this:
    You do not have the pins 1-37.
    Now I'm doing tests with a BlueGT with halogen headlights. It's from a friend who lives in Denmark, then take some time to know what are the results. All indications are that will be possible.
    The BlueGT has a BCM that is possible to activate the automatic lights, also the original vehicle wiring configuration (start/stop system) is similar to those that have xenon.
    Waiting for the results ...
    For VW POLO with halogen headlights without start/stop system, needs to be done a detailed study depending on equipment.
    The best solution is like the SEAT Ibiza 2011 6J.
    I've seen other solutions on the internet.
    On the follow page is a diagram that could be a good reference, but you must carefully consider all necessary relays for a VW POLO with halogen headlights without st/stp.
    http://uk-mkivs.net/topic/97467-vw-golf ... -and-play/
    At the moment I'm very busy. There are many people on this forum able to carefully study the automatic lights for vw polo with halogen headlights.
    Another solution is to wait for vw polo diagrams restyling 2014. This will have automatic lights with halogen headlights. :023
    Ok thanks a lot, you've been very kind ...
    Wait for some news in case you find a permanent solution.
    ciclo
    da ciclo » martedì 6 maggio 2014, 17:02
    Today at the dealership.
    6C1 with automatic lights and halogen headlights.
    Please, can anyone explain me about the format of the forum. :nonso
    da claudio-dj » mercoledì 7 maggio 2014, 15:25
    ask our admin juanpalmy! :023
    da claudio-dj » mercoledì 7 maggio 2014, 21:46
    Hello cycle
    I'm sorry again,
    Should I install the rear view of the Scirocco, and I wanted
    know if the connections are the same as you have in your emblem?
