POLO 6R 1.2 TSI 90CV R-LINE BIANCO 5p.
    ciclo
    Auto posseduta: 1.2 TSI R-Line
    Re: POLO 6R 1.2 TSI 90CV R-LINE BIANCO 5p.
    da ciclo » giovedì 29 agosto 2013, 12:27
    edit
    Ultima modifica di ciclo il lunedì 16 giugno 2014, 21:47, modificato 1 volta in totale.
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » giovedì 29 agosto 2013, 15:34
    Ciclo but if I use the same cable that has used the person who did it in the link you sent me, that's okay though?
    ciclo
    da ciclo » giovedì 29 agosto 2013, 16:22
    Ok. :045
    Do you already have the lamps?
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » giovedì 29 agosto 2013, 16:56
    no, I will buy on the alixpress and since I already give the cables with the connectors I thought of using the method of the link that you gave me so I do not buy other connectors but only the holder.
    Wiring that sells alixpress is formed as the picture I posted?
    This pictures:Immagine
    ciclo
    da ciclo » venerdì 30 agosto 2013, 3:27
    No. The wiring is configured exactly like this:
    http://img.tapatalk.com/3281225d-165d-00eb.jpg
    Aliexpress wiring is taped with cloth tape. Good quality.
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » venerdì 30 agosto 2013, 12:43
    Ciclo, I just bought the alixpress kit, how long it took to get to your home?
    ciclo
    da ciclo » venerdì 30 agosto 2013, 15:42
    edit
    Ultima modifica di ciclo il lunedì 16 giugno 2014, 22:03, modificato 1 volta in totale.
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » lunedì 2 settembre 2013, 0:27
    thank you very much ciclo, but if I wanted to use the cables that are in the alixpress kit I can connect the two wires crimped to the positive 65a and negative 4a of BCM?
    ciclo
    da ciclo » lunedì 2 settembre 2013, 8:59
    You can. :023
    I put an interconnect for two reasons, the first is to remove the seat without problems when I need it, and the second is because it facilitates the placement of the brackets inside the seat.
    Insert the brackets with the lights inside the seat is somewhat difficult if not completely removed upholstery.
    Ultima modifica di ciclo il lunedì 16 giugno 2014, 22:05, modificato 1 volta in totale.
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » lunedì 2 settembre 2013, 9:08
    Honestly I wanted to leave halogen bulbs inside because I have the beige upholstery ;)
    ciclo
    da ciclo » lunedì 2 settembre 2013, 9:31
    Be careful because the brackets take a lot of heat with halogen bulbs. I do not know if it could cause any problems.
    I tried it for fifteen minutes with halogen bulbs and did not burn the car ... :explo :talk
    The lighting with halogen bulbs I found it insufficient.
    Note that the space is small and if you like to wear the seat fully lowered with halogen bulbs you will lose plenty of lighting.
    Although the upholstery in beige ... :017
    ciclo
    da ciclo » lunedì 2 settembre 2013, 15:17
    New mod:
    White LED Interior Lights
    The images are of very low quality. Sorry. :cry:
    With flash.
    Without flash.
    True Color.
    Ultima modifica di ciclo il venerdì 14 marzo 2014, 18:56, modificato 1 volta in totale.
Visitano il forum: Nessuno e 28 ospiti
