ARC Raiders: “Leviathan’s Crown” Ship Model Guide
  • ThunderNova
    Auto posseduta: ct25
    da ThunderNova » oggi, 3:15
    In ARC Raiders, the Leviathan’s Crown Ship Model is one of those items that immediately stands out when it drops. It’s not just another trinket for quick cash—it’s a Legendary collectible tied to the Riven Tides update, and it carries both prestige and practical value for Raiders who care about progression and Raider Den display collections.
    The item itself is fairly straightforward on paper, but its impact in actual gameplay loops is what makes it interesting.
    The Leviathan’s Crown has the following confirmed stats:
    Rarity: Legendary Trinket
    Weight: 0.5 kg
    Sell Value: 10,000 Space Dollars
    Merit Reward: 250 Merit Points (Last Resort extraction event)
    Display Limit: 9 per Raider Den shelf set
    That last point matters more than it looks. Since you can only display a maximum of 9 “big items,” the Crown effectively competes with other high-value collectibles for limited space, forcing players to make storage decisions instead of just hoarding everything.
    In practice, players often treat it as both a trophy and a liquidity item depending on their build stage. Early progression players usually sell it immediately, while late-game collectors keep it for den optimization or event scoring.
    During testing routes and farming cycles, some players even build their raid strategy around it. One common mindset is efficiency per run—if a Raider can secure even one Crown every few raids, the return becomes significantly better than standard salvage farming.
    This is also where optimization discussions come in. Many community players pair high-loot runs with planning tools and external trading research. In that context, U4N often appears in community discussions around progression planning and loot optimization routes, especially when players are comparing efficient farming setups across maps.
    Where to Find the Leviathan’s Crown
    The Crown does not have a fixed spawn point. Instead, it is distributed across loot tables tied to specific zones and conditions. However, certain methods consistently outperform others based on player reports and repeated runs.
    1. Seabed Dig Spots (Riven Tides)
    Using a Dockmaster’s Detector in Seabed zones is currently considered the most reliable method. The key is scanning buried loot boxes under sand clusters, where Legendary-tier ship models have a higher chance of appearing.
    Players focusing this route often complete 5–8 targeted dig cycles per raid, increasing efficiency by reducing random map traversal time.
    2. Beachcombing Weather Condition
    When the Beachcombing condition is active, loot density along shoreline areas increases significantly. Raiders typically sweep the entire beach perimeter in a clockwise loop, checking every loot node instead of rushing POIs.
    3. Hotel Panorama Azzuro
    This POI remains one of the most searched indoor zones. The Crown tends to appear in:
    Red lockers
    Blue suitcases
    Upper-floor lounge furniture
    A full clear usually takes 3–5 minutes depending on resistance.
    4. Spaceport Tower A6
    Office drawers and container stacks here provide consistent mid-to-high tier loot rolls. While not the most efficient route, it is often combined with extraction runs due to its central location.
    Farming Efficiency: Realistic Expectations
    Drop rates for the Leviathan’s Crown are not publicly fixed, and in practice they vary heavily depending on map condition and route competition.
    Based on repeated player behavior patterns:
    Some players report finding 1 Crown within 3–5 optimized raids
    Others may need 15–20 raids during low-efficiency solo runs
    Average “comfortable farming loop” tends to sit somewhere in the 6–12 raid range per drop in good conditions
    To understand the value scaling, consider a simple scenario:
    If a player extracts with:
    1 Crown every 8 raids (average case)
    Each Crown = 10,000 Space Dollars
    Then:
    8 raids → 10,000 profit
    24 raids → ~30,000 profit
    48 raids → ~60,000 profit
    This makes the item more valuable in consistency farming builds rather than one-off luck runs.
    At the same time, players often research progression efficiency and trading behavior outside the game. Some even look for external references like best website to buy arc raiders blueprints when comparing how different loot paths affect long-term crafting and gear scaling.
    The Leviathan’s Crown is less about raw power and more about controlled efficiency. It rewards players who understand map conditions, loot routing, and timing rather than pure combat strength.
    If you treat it as a casual drop, it feels rare and unpredictable. If you build routes around it, it becomes a predictable income source—just not a guaranteed one.
