Path of Exile 2 continues to expand upon the deep character customization that made the original game famous, and among the newest and most exciting archetypes is the Hollow Palm Monk. Combining fast-paced melee combat, elemental damage scaling, and powerful Ascendancy interactions, this build offers a unique leveling experience that can carry players smoothly from the campaign into early mapping.
While the build has some rough moments during the early game, particularly in Act 1, it quickly evolves into a highly efficient character capable of freezing enemies, destroying bosses, and clearing maps at impressive speed. With the right Ascendancy choices, gear priorities, and skill setups, the Hollow Palm Monk becomes one of the most satisfying melee experiences currently available in POE 2 Chaos Orbs.
Understanding the Ascendancy
The Monk Ascendancy offers several interesting choices, but not all of them shine equally during the leveling process.
One of the first observations many players make is that several of the flashy Ascendancy nodes feel designed more for endgame than early progression. Skills such as Holo Focus Technique may look exciting on paper, but in practice they often feel underwhelming while leveling. The effect can be difficult to notice, and the summoned bells frequently appear in inconvenient locations, making them feel more like filler nodes than meaningful power spikes.
Instead, the strongest opening Ascendancy choice is often Way of the Mountain.
While not particularly exciting, Way of the Mountain provides exactly what every leveling character needs:
Increased damage
Additional survivability
Consistent performance
No complicated mechanics
The combination of offense and defense makes it ideal for progressing through the campaign.
The second Ascendancy point should almost always go into Way of the Stonefist. After extensive testing, this node stands out as one of the strongest leveling tools available to Monks. It transforms ordinary gloves into major damage multipliers by converting flat damage values into significantly stronger offensive scaling.
Even relatively mediocre gloves can become powerful sources of damage thanks to Stonefist's interaction with flat elemental and physical attack modifiers.
Why Way of the Stonefist Is So Strong
The strength of Stonefist comes from how effectively it scales flat damage.
Normally, low-tier flat damage rolls on gloves aren't particularly impressive. However, once converted through the Stonefist mechanics, these values become dramatically more impactful.
The damage increase is substantial. Players can often see tooltip damage jump by thousands simply by equipping gloves with appropriate flat attack modifiers.
Stonefist also converts useful utility stats:
Attack speed becomes Onslaught generation
Onslaught grants movement speed and skill speed
Mana-related bonuses become mana leech
Additional quality-of-life benefits improve leveling speed
The result is a node that provides both offensive power and smoother gameplay throughout the campaign.
The Challenge of Early-Level Monk Gameplay
Veteran Monk players already know one important truth: Act 1 is difficult.
The quarterstaff playstyle can feel weaker than alternative leveling methods during the opening stages of the game. Some players may prefer leveling with bows, crossbows, or other weapon types before transitioning into their final build.
However, players who stick with quarterstaff skills can still enjoy a strong leveling experience.
One standout option is Glacial Cascade.
The skill performs surprisingly well during the campaign thanks to its excellent damage output and strong freezing potential. To maximize effectiveness, players must learn to position correctly because Glacial Cascade features a sweet spot mechanic.
When enemies are struck at maximum range by the largest ice spike, the skill deals significantly increased damage, making proper spacing extremely rewarding.
Frozen Locus: The Real Campaign MVP
Although several skills can be used throughout leveling, Frozen Locus arguably does the most work.
The skill functions by causing the Monk to dash backward while leaving behind an icy construct. When enemies attack or destroy the construct, it explodes and deals substantial area damage.
This simple mechanic offers several advantages:
Excellent pack clearing
Strong area damage
Safe positioning
Consistent scaling
Frozen Locus works effectively regardless of which primary attack skill is being used. Whether players prefer Ice Strike, Storm Wave, or Glacial Cascade, Frozen Locus remains one of the most reliable leveling tools available.
For many Monks, it becomes the foundation of their entire campaign strategy.
Ice Strike and Bell Synergy
While ranged Monk skills are popular among many players, Ice Strike remains one of the most enjoyable melee-focused options.
Ice Strike gains particular value because it generates the combo points necessary for Bell mechanics. Since Bell is one of the Monk's most iconic and visually satisfying abilities, many players naturally gravitate toward Ice Strike despite alternative leveling methods being available.
At around level 14, acquiring Ice Strike alongside Frozen Locus creates a powerful combination that remains effective throughout the campaign.
The gameplay loop is simple:
Dash into position.
Place Frozen Locus.
Trigger the explosion.
Attack with Ice Strike.
Generate combo points.
Summon Bell.
Repeat.
This rotation offers excellent damage while maintaining the fluid combat style that defines the Monk class.
Mobility Through Pounce
Movement speed plays a huge role in leveling efficiency, and Pounce becomes an important tool for maintaining momentum.
Pounce requires a talisman but does not demand specific affixes. Even a mediocre talisman can unlock significant mobility improvements.
The interaction with Wolf Form is especially valuable:
Faster movement speed
Sprint capability
Automatic transformation back into combat form
Improved mapping efficiency
Players should be aware of a current issue involving Charge Staff. Shapeshifting while using Charge Staff can cause the buff to stop functioning correctly despite appearing active. Until fixed, this interaction requires caution.
The Importance of Hollow Palm Technique
Perhaps the most critical milestone in the build's progression is acquiring Hollow Palm Technique.
Many players consider this node nearly mandatory for Monk leveling due to the enormous benefits it provides.
Hollow Palm Technique offers:
Massive stat bonuses
Weapon independence
Increased speed
Reliable damage scaling
Simplified gearing
Once obtained, the campaign becomes noticeably easier. Damage spikes significantly, enemies freeze more consistently, and bosses become far less threatening.
The node fundamentally transforms how the character scales and serves as the foundation for the entire build.
Gear Priorities While Leveling
Proper gearing is essential for maintaining strong damage output.
Rings
Rings provide some of the most important offensive stats available during leveling.
The primary goal is stacking flat attack damage:
Cold damage to attacks
Fire damage to attacks
Lightning damage to attacks
Physical damage to attacks
Flat damage contributes far more to overall performance than life or defensive modifiers during the campaign.
While resistances remain important, killing enemies quickly often provides more practical survivability than defensive stats alone.
Gloves
Gloves represent another major source of power.
Priority stats include:
Flat attack damage
Attack speed
Mana leech
Attack speed is particularly valuable because of its interaction with Stonefist and Onslaught generation.
Amulets
Skill levels are incredibly powerful for scaling damage.
A +1 to melee skills amulet should be acquired as early as possible. Later, players can upgrade to a +2 version once currency becomes available.
Even a simple amulet with skill levels and basic resistances can significantly improve performance.
Armor
Evasion is the primary defensive stat during leveling.
Because Hollow Palm Technique converts evasion into offensive benefits, stacking evasion provides both defense and damage.
This dual-purpose scaling makes evasion gear the most efficient option throughout the campaign.
Passive Tree Progression
The passive tree follows a straightforward path:
Grab early attack speed nodes.
Secure attack damage clusters.
Rush Hollow Palm Technique immediately.
Continue stacking attack speed.
Acquire elemental damage clusters.
Transition toward critical strike scaling later.
The early focus remains entirely on consistency and speed.
Critical strike investment should generally wait until around level 50 when sufficient passive points become available.
At that stage, key nodes such as:
Strikethrough
Deadly Force
True Strike
begin providing enough value to justify the transition.
Combined with Hollow Palm's critical strike scaling and Blind synergies, critical hits become a major source of endgame damage.
Essential Skill Setup
Several skills form the core of the build.
Ice Strike
Primary support priorities include:
Rapid Attacks
Rage
Additional elemental scaling supports
These gems provide the largest damage increase during leveling.
Frozen Locus
Frozen Locus remains the primary clearing tool throughout the campaign.
Its consistent explosions make it indispensable for efficient progression.
Herald of Ice
Herald of Ice offers:
Additional damage
Freeze synergy
Excellent clear speed
It should be acquired as soon as possible.
Herald of Thunder
Another strong offensive aura that complements the build's elemental focus.
Frost Bomb
Frost Bomb provides exposure and dramatically improves boss damage.
Players should use it regularly against tougher enemies.
Hand of Chayula
This skill serves as an important debuff tool for boss encounters.
When combined with Frost Bomb, it creates a powerful damage amplification setup.
Bossing Rotation
Single-target combat requires more setup than general mapping.
The ideal sequence looks like this:
Apply Hand of Chayula.
Cast Frost Bomb.
Attack to generate combo.
Summon Bell.
Continue attacking Bell.
Refresh debuffs when necessary.
Repeat.
This rotation maximizes Bell uptime and generates impressive boss damage throughout the campaign and into early maps.
Transitioning Into Endgame
By the time players enter maps, the build begins shifting toward critical strikes and more specialized gear.
Important upgrades include:
Strong flat-damage rings
Higher-level skill amulets
Hybrid Evasion/Energy Shield gear
Additional mana sustain
Critical strike scaling
One particularly exciting future option is Hollow Resonance, the Ascendancy node that creates explosive effects whenever critical strikes occur.
This mechanic introduces additional area damage and promises significant scaling potential for later content.
Final Thoughts
The Hollow Palm Monk is shaping up to be one of the most enjoyable melee leveling experiences currently available in Path of Exile 2. Although the build starts slowly and some Ascendancy nodes feel underwhelming during the campaign, its power rapidly increases once Hollow Palm Technique and Way of the Stonefist are acquired cheap POE 2 Chaos Orbs.
Strong freezing capability, excellent mobility, satisfying Bell gameplay, and surprisingly high damage make the build effective in nearly every stage of progression. The combination of Ice Strike, Frozen Locus, and Hollow Palm scaling creates a character that feels fast, powerful, and rewarding to play.
While questions remain regarding long-term survivability and endgame optimization, the build already demonstrates impressive potential. For players looking for a melee-focused Monk that combines speed, elemental damage, and stylish combat mechanics, the Hollow Palm Monk may be one of the strongest and most entertaining options Path of Exile 2 currently has to offer.
