Ciao , se vuoi avere una copia perfettamente funzionante devi avere un Portatile o PC fisso con Linux con lettore di scheda SD PCI (non USB) poi una SD o microSD Samsung Evo Plus Made In Korea.Andrea 6r ha scritto:io ho comprato su ebay delle mappe aggiornate http://www.ebay.it/itm/172785532702?ul_noapp=true ma non riesco a copiare su un'altra SD più grande comparendo un messaggio d'errore
devi fare un cd? eventualmente come?
Codice: Seleziona tutto
Here is how to prepare SD for RNS310
1 - Card EVO/EVO+ (I tried 32G and 64G SD)
2 - Format card in Windows (by Guiformat.exe utility) and copy cryptnav on card . Nothing more!
3 - Start Laptop from boot flash Ubuntu (previously created in PC by LiLi USB Creator)
4 - Copy file mmc and mmc32 to Desktop
5 - Right cick -> open terminal, then go to the Desktop folder ( by command "cd Desktop" )
6 - Make command execution rights by command "chmod 777 mmc32" and "chmod 777 mmc"
7 - Insert the SD in slot. Terminal command "df" and verify the name card.
Somewhere down everything must occur "mmcblk0" + p + a number.
The suffix p "number" is the partition on the card, we are not interested, just use "mmcblk0".
When you do not see anywhere mmcblk0 ,
you must try different Laptop with on matherboard integrated cardreader.
Now you can read the original CID by command "cat / sys / block / mmcblk0 / device / cid"
310 East V8 CID is : 0941504146205344021349037f00fa00
[b]310 West V9 CID is : 094150414620534402107e426c010b01
[/b]
8 - change CID by terminal command:
"sudo ./mmc32 prog_cid / dev / mmcblk0 0941504146205344021349037f00fa00"
or
"sudo ./mmc prog_cid / dev / mmcblk0 0941504146205344021349037f00fa00"
Writing new CID: 0941504146205344021349037f00fa00
Success! Remove and Reinsert SD card to check new CID.
If you do not see messages about success, remove and reinsert SD card
and check CID by command "cat /sys/block/mmcblk0/device/cid"
Now will be displaying the new CID 0941504146205344021349037f00fa00
You should see 0941504146205344021349037f00fa01 line.
The last two characters may be different, for example, be 69.
If CID changed besides the last two numbers, so it's okay.
On the last two numbers does not matter,
it's just a checksum, which generates SD card itself.
If the CID unchanged try again command for changing, remove and reinsert SD card
If not change, try the same command, but with different bit version of mmc,
If is changed, go to car :-)
