da blumes » mercoledì 1 aprile 2009, 18:28
ciao ragazzi vi posto i risultati della mia diagnosi:
da quel che ho capito ho qualche problema al motore, abs e clima, chi mi spiega meglio?
grazie
VAG-COM Version: Release 311.2-N
Chassis Type: 6N2 - VW Polo
Scan: 01,02,03,08,15,17,19,25,35,41,45,46,55
Address 01 -------------------------------------------------------
Controller: 045 906 019 AB
Component: 1,4l R3 EDC 0000SG 1210
Coding: 00003
Shop #: WSC 31414
WVWZZZ6NZ1D088757 VWZ1Z0A1540058
1 Fault Found:
19464 - Camshaft Position Sensor (G40): Signal Out of Range
P3008 - 00-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6X0 907 379 B
Component: ABS 30 IE CAN V004
Coding: 05603
Shop #: WSC 31414
1 Fault Found:
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 14000
Shop #: WSC 31414
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
37-10 - Faulty - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6N0 920 804 M
Component: KOMBIINSTRUMENT TRW V12
Coding: 00132
Shop #: WSC 00012
No fault code found.
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN
Coding: 00022
Shop #: WSC 31414
Address 25 -------------------------------------------------------
Controller: 6X0 953 257
Component: IMMO 0008
Coding: 00001
Shop #: WSC 00000
Address 45 -------------------------------------------------------
Controller: 6N0 951 171 C
Component: Innenraumueberw. 0003
Address 46 -------------------------------------------------------
Controller: 6N0 959 799 B
Component: 8T Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31414
End -------------------------------------------------------
