Lettura diagnosi vag...
Inviato: lunedì 19 gennaio 2009, 23:15
dato che stiamo diventando sempre di piu con il cavo vag e sempre meno a saperlo usare bene... direi di inserire qua i risultati che vengono fuori dalle varie diagnosi per avere un aiuto... inizio io...
diagnosi della macchina di stefano...
VAG-COM Version: Release 311.2-N
Chassis Type: 9N1 - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller:
Note: Can't Synch Baud Rate
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 00788
No fault code found.
Address 08 -------------------------------------------------------
Controller: 6Q0 820 045
Component: Klimaanlage X0840
6 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to B+ - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
28-00 - Short to B+
29-10 - Short to Ground - Intermittent
28-10 - Short to B+ - Intermittent
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S32
Coding: 25742
Shop #: WSC 00788
1 Fault Found:
01598 - Drive Battery Voltage
07-10 - Signal to Low - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Q0 920 820
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 01141
Shop #: WSC 00000
WVWZZZ9NZ3Y030840 VWZ7Z0B5178818
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 00 GATEWAY CAN 1S32
Coding: 00014
Shop #: WSC 00788
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00110
Shop #: WSC 00788
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 3P Komfortgerát 0001
Coding: 00065
Shop #: WSC 00788
End --------------------------------------------------
Controller:
Coding: 0001097
Shop #: WSC 00788
6 Faults Found:
28-00 - Short to B+
Coding: 25742
Shop #: WSC 00788
1 Fault Found:
Coding: 01141
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 00788
Coding: 00110
Shop #: WSC 00788
Coding: 00065
Shop #: WSC 00788
Come mai a me da questo risultato?
