Lettura diagnosi vag...
    salvyx87
    Feedback: 29
    nome: Salvo
    Re: Lettura diagnosi vag...
    da salvyx87 » domenica 9 agosto 2009, 18:11
    raga ho fatto la diagnosi con vag, e mi ritrovo con un po di errori. li ho cancellati tutti e ho rifatto di nuovo la diagnosi. mi risultano ancora errori: sapete spiegarmi che errori sono??
    PRIMA
    VAG-COM Version: Release 311.2-N
    Chassis Type: 9N1 - VW Polo
    Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
    Address 01 -------------------------------------------------------
    Controller: 038 906 019 NC
    Component: 1,9l R4 EDC G000SG 6138
    Coding: 00002
    Shop #: WSC 00788
    WVWZZZ9NZ6Y253795 VWZ7Z0F3852664
    2 Faults Found:
    18263 - Powertrain Data Bus: Software Version Monitoring
    P1855 - 35-00 - -
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-00 - -
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 6Q0 907 379 AF
    Component: ABS 8.0 front H04 0002
    Coding: 0002193
    Shop #: WSC 00788
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller: 6Q0 820 045
    Component: Klimaanlage X0840
    Address 09 -------------------------------------------------------
    Controller: 6Q1 937 049 D
    Component: 00BK BN-SG. 1S34
    Coding: 09358
    Shop #: WSC 00788
    2 Faults Found:
    01598 - Drive Battery Voltage
    07-00 - Signal to Low
    00778 - Steering Angle Sensor (G85)
    49-00 - No Communications
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 6Q0 920 842 K
    Component: KOMBI+WEGFAHRSP VDO X05
    Coding: 01542
    Shop #: WSC 80019
    WVWZZZ9NZ6Y000012
    Address 19 -------------------------------------------------------
    Controller: 6N0 909 901
    Component: 0B7L GATEWAY CAN 1S34
    Coding: 00014
    Shop #: WSC 00788
    1 Fault Found:
    Address 44 -------------------------------------------------------
    Controller: 6Q0 423 156 AB
    Component: LenkhilfeTRW V270
    Coding: 10150
    Shop #: WSC 00788
    Address 46 -------------------------------------------------------
    Controller: 6Q0 959 433 E
    Component: 3F Komfortgerát 0002
    Coding: 00019
    Shop #: WSC 00788
    Address 56 -------------------------------------------------------
    Controller: 6Q0 035 152 A
    Component: Radio BVX 005 0004
    Coding: 0040400
    Shop #: WSC 00788
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    End -------------------------------------------------------
    DOPO
    Coding: 00002
    Shop #: WSC 00788
    2 Faults Found:
    P1855 - 35-00 - -
    P1650 - 35-00 - -
    Readiness: N/A
    Coding: 0002193
    Shop #: WSC 00788
    Coding: 09358
    Shop #: WSC 00788
    1 Fault Found:
    Coding: 01542
    Shop #: WSC 80019
    WVWZZZ9NZ6Y000012
    Coding: 00014
    Shop #: WSC 00788
    1 Fault Found:
    Coding: 10150
    Shop #: WSC 00788
    Coding: 00019
    Shop #: WSC 00788
    Coding: 0040400
    Shop #: WSC 00788
    1 Fault Found:
    000 - -
    la mia bella bimba
    modifiche fatte:
    da gringo14 » lunedì 10 agosto 2009, 19:27
    :015 :015 :015
    Certo che sta facendo la strage sto G85 :013
    Tu non hai l'esp vero Salvo? :017
    Guarda, per gli altri errori non ti so dire, ma io l'unica soluzione che mi ha permesso di resettare gli stessi errori che hai tu sul 9 e 19 del G85 è stato quello di cambiare momentaneamente il softcode del modulo 19 da 00014 a 0006 (disabilita il servosterzo) e poi rimettere il 00014.... come per magia l'errore poi riesci a resettarlo.... :023
    Ovviamente colgo l'occasione per RI-Ringraziare ancora una volta Matteo, visto che il suggerimento non poteva che arrivare da lui!!! :pray
    salvyx87
    Feedback: 29
    nome: Salvo
    da salvyx87 » mercoledì 12 agosto 2009, 11:08
    niente esp. ieri ho fatto di nuovo la diagnosi, cancellando gli errori, e a parte questi (G(% che oggi provo a cancellare cn la procedura di Nino), mi è rimasto solo quello sul modulo 56, e nache cancellandolo si ripresenta.
    Coding: 0040400
    Shop #: WSC 00788
    1 Fault Found:
    000 - -
    cosa significa??? :017 :017
    la mia bella bimba
    modifiche fatte:
    vale9n3
    Feedback: 19
    nome: Valentina
    da vale9n3 » mercoledì 12 agosto 2009, 11:52
    salvyx87 ha scritto:niente esp. ieri ho fatto di nuovo la diagnosi, cancellando gli errori, e a parte questi (G(% che oggi provo a cancellare cn la procedura di Nino), mi è rimasto solo quello sul modulo 56, e nache cancellandolo si ripresenta.
    Coding: 0040400
    Shop #: WSC 00788
    1 Fault Found:
    000 - -
    Hai attaccato lo scatolino mp3? Nel caso l'ultima cifra deve essere +2 che è il cd charger. Altro non mi viene in mente
    Polo 9n3 1.4TDI 27.07.2005
    da m2312l » mercoledì 12 agosto 2009, 11:55
    si è il cd changer sicuro... cambia il softcode in 0040402 e sei a posto
  • giangiuGTI
    da giangiuGTI » mercoledì 2 settembre 2009, 17:06
    Controller:
    Note: Can't Synch Baud Rate
    Controller: 6Q0 907 379 L
    Component: ABS FRONT MK60 0101
    Coding: 0001097
    Shop #: WSC 00788
    1 Fault Found:
    01276 - ABS Hydraulic Pump (V64)
    012 - Electrical Fault in Circuit
    5 Faults Found:
    01596 - Motor for Outside/Recirculated Air Flap (V154)
    30-00 - Open or Short to B+
    29-10 - Short to Ground - Intermittent
    28-00 - Short to B+
    01317 - Control Module in Instrument Cluster (J285)
    79-00 - Please Check Fault Codes
    Controller: 6Q1 937 049 C
    Component: 00 BN-SG. 1S32
    Coding: 25742
    Shop #: WSC 00788
    4 Faults Found:
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    27-00 - Implausible Signal
    00969 - Fuse for Heated Rear Window (S41)
    37-00 - Faulty
    07-10 - Signal to Low - Intermittent
    Controller: 6Q0 920 820
    Component: KOMBI+WEGFAHRSP VDO V13
    Coding: 01551
    Shop #: WSC 00000
    WVWZZZ9NZ3Y030840 VWZ7Z0B5178818
    2 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    29-00 - Short to Ground
    Component: 00 GATEWAY CAN 1S32
    Coding: 00014
    Shop #: WSC 00788
    1 Fault Found:
    Controller: 6Q0 423 156 M
    Component: LenkhilfeTRW V210
    Coding: 00130
    Shop #: WSC 00788
    Component: 3P Komfortgerát 0001
    Coding: 00065
    Shop #: WSC 00788
    :003
    che ne dite??? polo di stefano...
    con spia abs accesa... spia aribag accesa e clacson non funzionante... e spia freni accesa per colpa del filo tranciato... inoltre da qualche giorno non segnala piu la temperatura...
  • Robbie_9n3
    Auto posseduta: ---
    da Robbie_9n3 » mercoledì 2 settembre 2009, 18:02
    x il clacson provato a vedere il fusibile :017 :023
  • giangiuGTI
    da giangiuGTI » mercoledì 2 settembre 2009, 19:08
    si si... gia riesco a districarmi in qualche maniera...e che non ho tempo per lavorare sulla mia...figurati su quella di STe... :003
  • Robbie_9n3
    Auto posseduta: ---
    da Robbie_9n3 » mercoledì 2 settembre 2009, 19:35
    giangiuGTI ha scritto:si si... gia riesco a districarmi in qualche maniera...e che non ho tempo per lavorare sulla mia...figurati su quella di STe... :003
    :023
    Murdok
    Feedback: 18
    Auto posseduta: 9n3 Sportline
    da Murdok » giovedì 3 settembre 2009, 15:42
    non avevo mai visto cosi tanti errori :009
    Don't Be Evil
    da pariduzz86 » giovedì 3 settembre 2009, 15:57
    :woo e io che mi lamentavo che mi uscivano 5 errori! :009
    ma cosa avete combinato? ci sono molte segnalazioni di corto :011
  • giangiuGTI
    da giangiuGTI » giovedì 3 settembre 2009, 20:15
    non dirlo a me... per l'abs... ho provatto a resettare...ma nulla...torna come prima...
    stefano e il suo super impianto audio... non vi ho detto che gli ha preso fuoco... :009
