Lettura diagnosi vag...
  • redevil46
    Re: Lettura diagnosi vag...
    da redevil46 » mercoledì 27 maggio 2015, 18:26
    Ciao a tutti.. qualcuno mi aiuta gentilmente a leggere la mia scansione ? è un polo 9n
    DEVO CAPIRE IL MOTIVO PER CUI NON PARTE IL CLIMA
    VCDS Version: Beta 12.10.3
    Data version: 20130228
    Wednesday,27,May,2015,20:10:59:55062
    Chassis Type: 9N - VW Polo
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ3D137706 Mileage: 262900km/163358miles
    Address 01: Engine Labels: Redir Fail!
    Part No: 045 906 019 AP
    Component: 1,4l R3 EDC 0000SG 1554
    Coding: 00002
    Shop #: WSC 31414
    VCID: 63CE18E6F182AE06F27
    WVWZZZ9NZ3D137706 VWZ7Z0B6442151
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS2.lbl
    Part No: 6Q0 907 379 L
    Component: ABS FRONT MK60 0101
    Coding: 0001097
    Shop #: WSC 31414 000 00000
    VCID: 4688E1723270FB2EF59
    Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
    Part No: 6Q0 820 045
    Component: Klimaanlage X0840
    VCID: EAD0F5C296A87F4EB11
    1 Fault Found
    01596 - Motor for Outside/Recirculated Air Flap (V154)
    55-00 - Adaptation Not Successful
    Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
    Part No: 6Q1 937 049 C
    Component: 00 BN-SG. 1S33
    Coding: 09358
    Shop #: WSC 31414
    VCID: 3B7E808629B2B6C69A7
    3 Faults Found
    00511 - Selector Lever (E313)
    49-00 - No Communications
    00778 - Steering Angle Sensor (G85)
    01324 - Control Module for All Wheel Drive (J492)
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 K
    Component: 0L AIRBAG VW51 0P 0006
    Coding: 12364
    Shop #: WSC 31414
    VCID: 2C5CB3DADCDC217E03D
    Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
    Part No: 6Q0 920 820 L
    Component: KOMBI+WEGFAHRSP VDO V15
    Coding: 01132
    Shop #: WSC 00000
    VCID: 38749F8A18849DDE775
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: 09 GATEWAY CAN 1S33
    Coding: 00014
    Shop #: WSC 31414
    VCID: F0E4E7AAB074859EFF5
    3 Faults Found
    Address 44: Steering Assist Labels: None
    Part No: 6Q0 423 156 R
    Component: LenkhilfeKYO V913
    Coding: 10140
    Shop #: WSC 31414
    VCID: 3E7889923AA0A3EEBD9
    Address 45: Inter. Monitor Labels: 6Q0-951-171.lbl
    Part No: 6Q0 951 171
    Component: Innenraumueberw. 0019
    VCID: EFE6E4D6AD4A9A66E6F
    Address 46: Central Conv. Labels: 6Q0-959-433.lbl
    Part No: 6Q0 959 433 E
    Component: 4P Komfortgerát 0002
    Coding: 00066
    Shop #: WSC 31414
    VCID: 3D7A8E9E37A6B8F6A43
    Subsystem 1 - Part No: 6Q2959802A
    Component: 4P Tõrsteuer.FS TFK 0004
    Subsystem 2 - Part No: 6Q2959801A
    Component: 4P Tõrsteuer.BF TFK 0004
    da bonzo86 » mercoledì 27 maggio 2015, 18:36
    hai il motorino del ricircolo che non va. Fallo controllare da un elettrauto. Inoltre hai anche altri problemi. una volta che vai, fatti fare una diagnosi con un brein bee o un bosch.
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » sabato 27 giugno 2015, 12:09
    ragazzi mi sapreste dire che problemi ha la mia auto? soprattutto nel modulo 10-Park/Steer Assist perche non mi fa entrare nel modulo e mi da l'errore che riporta nella scansione, dovrei modificare alcuni bit per attivare la retrocamera ma non so proprio come fare. vi ringrazio
    Saturday,27,June,2015,12:41:22:37412
    VCDS Version: Release 11.11.0
    Data version: 20111111
    Chassis Type: 6N0
    Scan: 01 03 08 09 10 15 17 19 25 37 44 55 56 77 0B
    VIN: WVWZZZ6RZBY277278
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    37-Navigation -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine (J623-CGPA) Labels: None
    Part No SW: 03E 906 019 B HW: 03E 906 019 B
    Component: SIMOS11.1 H03 9878
    Revision: --H03--- Serial number:
    Coding: 00110016000400080000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM12MPI02103E906019B 001011
    ROD: EV_ECM12MPI02103E906019B.rod
    VCID: 234F9E282ACEE76
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
    Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Coding: 210224E3217400B9842724E984D900401300
    VCID: 87176AB83236AB6
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
    Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
    Component: Man AC 02 0101
    Revision: 0002S 02
    VCID: 32616B6C6D347EE
    Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
    Part No SW: 7H0 937 089 D HW: 7H0 937 089
    Component: BCM T5GP Li4 H47 0230
    Revision: BS047001 Serial number: 0398 078111260
    Coding: 3CB02BBF08A10000003808B17C2B0DD15AC8670F60051041200000000000
    VCID: 37775A7886569B6
    Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 006 0903
    Coding: 18BC30
    Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 007 1611
    Coding: 08BC30
    Subsystem 3 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
    Component: E221__MFL-TAS H07 0013
    Coding: 020000
    Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 007 1611
    Coding: 08BC32
    Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 007 1611
    Coding: 08BC32
    Address 10: Park/Steer Assist
    Cannot be reached
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag022 H09 0020
    Revision: -------- Serial number: 003GX00HMGR5
    Coding: 003232
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW25.rod
    VCID: 4A91138CEDA416E
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB40570DUOG79P0
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB40590DUOG2PB0
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515RRB404R0H1GGCGT6
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3525RRB404T0H1GGC89O
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 860 F HW: 6R0 920 860 F
    Component: KOMBI H05 0304
    Serial number: 00000000000000
    Coding: 140E00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
    ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
    VCID: 37775A788E569B6
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 7H0 937 089
    Component: GW-K-CAN TP20 0230
    Coding: 002200
    VCID: F0E5216423B88CE
    1 Fault Found:
    03075 - Parallel Parking Assistance Control Module (J791)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 2
    Mileage: 39030 km
    Time Indication: 0
    Date: 2104.14.25
    Time: 15:19:08
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0304
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
    VCID: EAD1330C0D6476E
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 F HW: 1T0 035 680 F
    Component: RNS-MID H55 3970
    Revision: AB001001 Serial number: VWZ6Z7L9185093
    Coding: 04000442040000900000
    Shop #: WSC 01357 011 00200
    ASAM Dataset: ------------------------- ------
    VCID: 316364606832456
    5 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 254
    Reset counter: 99
    Mileage: 39024 km
    Time Indication: 0
    00876 - Treble Speaker Rear Left (R14)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 134
    Mileage: 44928 km
    Time Indication: 0
    00877 - Treble Speaker Rear Right (R16)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 134
    Mileage: 44928 km
    Time Indication: 0
    02873 - Control Module for Back-Up Camera (J772)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 139
    Mileage: 44944 km
    Time Indication: 0
    00862 - Antenna for GPS Navigation (R50/R52)
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 39800 km
    Time Indication: 0
    Date: 2106.14.02
    Time: 16:25:23
    Address 44: Steering Assist Labels: 6Q0-423-156.lbl
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11250
    Shop #: WSC 00788
    VCID: 2F676218EA06536
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 6R0 907 357 HW: 6R0 907 357
    Component: LWR-ECU H02 0070
    Revision: -------- Serial number: --------------
    Coding: 0110000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
    ROD: EV_HeadlRegulVWLWRPt_VW25.rod
    VCID: F7F71A784ED6DB6
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    5 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 99
    Mileage: 39024 km
    Time Indication: 0
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 99
    Mileage: 44928 km
    Time Indication: 0
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 99
    Mileage: 44928 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 3
    Reset counter: 139
    Mileage: 44944 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 39800 km
    Time Indication: 0
    Date: 2106.14.02
    Time: 16:25:23
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
    Component: TELEFON H15 3200
    Revision: 1B001001 Serial number: 00007663112816
    Coding: 0400000000010110
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_VW25.rod
    VCID: 3B7F4648B27EBF6
    Address 0B: Sec. Air Heating
    Cannot be reached
    da bonzo86 » sabato 27 giugno 2015, 12:19
    Sul modulo 10 non legge nulla, poi hai dei problemi sulle connessioni, probabile dietro l'autoradio perché parla di circuito aperto su antenna, cassa posteriore destra e sinistra, antenna gps e modulo retrocamera. Prova a cancellare gli errori se hao fatto qualche lavoro e rifai il test.
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » sabato 27 giugno 2015, 12:28
    ho provato a cliccare su "clear all DTCs" ma gli errori rimangono. Eppure funziona tutto correttamente tranne la retrocamera che non sono riuscito ad attivare. Probabilemente mi da errore perchè ho attivato solo il bit nel modulo 37-navigation ma non nel modulo 10-park/steer assist infatti quando metto la retro ho il video sdoppiato dei sensori piu la visule della retrocamera ma vedo tutto nero. Cosa mi consigli?
    da bonzo86 » sabato 27 giugno 2015, 12:30
    La retrocamera è originale?
    Io rivedrei i collegamenti fisicamente e magari se hai attivato qualcosa via vag tornerei indietro. Quali sono le modifiche che hai fatto anche a livello di gps?
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » sabato 27 giugno 2015, 12:38
    la retrocamera è originale, i collegamenti sono stati fatti correttamente, ho provato con il tester. Gli errori all'antenna gps e a quella radio potrebbero essere dipesi da fatto che ho sostituito l'antenna a pinna con la canna, che danno come optional con il navigatore di fabbrica, con quella a pinna della golf 6. le modifiche via vag che ho fatto sono CDB, bluetooth (microfono + comandi vocali e telefono al volante), aux, TPMS, chiusure delle porte automatica.
    da bonzo86 » domenica 28 giugno 2015, 10:53
    Allora non penso ci sia qualcosa di strano...potrei imputare il fatto della sostituzione della pinna con la canna ma non so fino a quanto può essere colpevole.
    Io andrei in una officina e farei fare una diagnosi con qualche diagnostico più serio.
    Oltre agli errori, noti qualcosa di strano nell'uso quotidiano?
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » domenica 28 giugno 2015, 11:24
    Per quanto riguarda l'elettronica va tutto alla grande, non ho mai riscontrato malfunzionamenti, solo un piccolo calo a livello di segale dell'antenna radio da quando l'ho cambiata. Comunque proveró ad andare in conce a farmi attivare la retrocamera
    da bonzo86 » domenica 28 giugno 2015, 12:23
    facci sapere come si muovono.
  • Nuccioarc
    nome: Nuccioarc
    codici errore della mia polo 6r
    da Nuccioarc » giovedì 2 luglio 2015, 18:44
    ciao a tutti oggi ho effettuato uno scan con il vag della mia polo 6r, ha trovato vari codici errore, tuttavia la macchina non ha nessuna spia accesa e nessun problema, sapreste dirmi a cosa sono dovuti?
    ps: la rcd l'ho montata io, sostituendo una rmt 100 e va perfettamente in tutto soltanto che da errore
    infine sapreste dirmi come cambiare lo sfondo dell'rcd 510 ho provato a seguire la guida ma non ci riesco. grazie a tutti
    Thursday,02,July,2015,17:35:08:33490
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140905
    VIN: WVWZZZ6RZCY085613 License Plate:
    Chassis Type: 6R (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    09-Cent. Elect. -- Status: Malfunction 0010
    56-Radio -- Status: Not registered 0011
    Address 01: Engine (J623-CAYB) Labels: 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 MA HW: 03L 907 425 B
    Component: 1,6l R4 CR td H33 8849
    Revision: --H33--- Serial number:
    Coding: 00114016000400080000
    ASAM Dataset: EV_ECM16TDI02103L906023MA 003004
    ROD: EV_ECM16TDI02103L906023LK_SK25.rod
    VCID: 71EFA39FA02BC896643-8024
    Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
    Revision: --------
    Coding: 210228E3417500B7842B14E382D400421100
    VCID: 871B6D4732AF66265A7-80D2
    Revision: 0002S 02
    VCID: 326D6C936DADB38E5D9-8067
    Part No SW: 6R0 937 087 K HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0251
    Revision: BF046001 Serial number: 0434 239112876
    Coding: 24B02BBF08A10000003008006D2B0CD00000412F6086000020 0000000000
    VCID: 4587274FCC233436E8B-8010
    Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 008 1611
    Coding: 18BC30
    Component: J387__TSG_BT 008 1611
    Coding: 08BC30
    Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 008 1611
    Coding: 08BC32
    Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Coding: 08BC32
    2 Faults Found:
    00968 - Right Turn Signals
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 221
    Mileage: 27229 km
    Time Indication: 0
    Date: 2042.14.13
    Time: 10:27:20
    00967 - Left Turn Signals
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 248
    Mileage: 27399 km
    Time Indication: 0
    Date: 2042.14.17
    Time: 18:09:00
    Revision: -------- Serial number: 003GX00VCH1R
    Coding: 003232
    ROD: EV_AirbaVW10BPAVW250.rod
    VCID: 4A9D1473ED3DDB4E059-801F
    Serial number: 3575HRB40610Q3SK7OVA
    Serial number: 3585HRB405V0Q3SK2GKG
    Serial number: 3515RRB404P0NS9Q61MC
    Serial number: 3525RRB405N0NI3G292D
    Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
    Component: KOMBI H04 0206
    Serial number: 00000008715996
    Coding: 140200
    ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
    ROD: EV_DashBoardUDSJCIPQ25_VW25.rod
    VCID: 3A7D44B3BDDD4BCE959-806F
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H46 0251
    Revision: BF046001
    Coding: 002200
    VCID: F0E9269B2321419EEBD-80A5
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 27198 km
    Time Indication: 0
    Date: 2042.14.12
    Time: 16:45:30
    Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
    Component: IMMO H04 0014
    Serial number:
    ASAM Dataset: EV_ImmobUDSJCIPQ25 Unknown
    ROD: EV_ImmobUDSJCIPQ25_SK25.rod
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Coding: 11230
    Shop #: WSC 00788
    VCID: 2F6B65E7EA9F9E66327-807A
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 F HW: 3C8 035 195 F
    Component: Radio RCD510 050 0207
    Revision: 00000001 Serial number: VWZ1Z3L7687771
    Coding: 0500040004000C
    Shop #: WSC 01324 020 00200
    VCID: 2B5371F74A87E2461EF-807E
    1 Fault Found:
    00821 - Antenna 2 for Radio (R93)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 178
    Mileage: 27198 km
    Time Indication: 0
    Date: 2042.14.12
    Time: 16:45:50
    da bonzo86 » giovedì 2 luglio 2015, 18:59
    ho spostato nella sezione adatta, facciamo attenzione, cmq cancella gli errori e prova a fare un nuovo scan.
