Lettura diagnosi vag...
    Re: Lettura diagnosi vag...
    da claudio-dj » giovedì 2 maggio 2013, 15:45
    ahahahahah ok :019
    crime26
    Auto posseduta: nuova polo 6r
    nome: Gioacchino
    da crime26 » lunedì 6 maggio 2013, 8:12
    Ciao Ragazzi, questa è la mia diagnosi, sapete aiutarmi? Grazie....
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    37-Navigation -- Status: Not registered 0011
    56-Radio -- Status: Malfunction 1010
    Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
    Component: BCM PQ25 H+4 H46 0207
    Revision: BF046001 Serial number: 0147 057100377
    Coding: 3CB02BBF08A10000003004003D2B8CD00000410F60060000200000000000
    Shop #: WSC 12469 483 00190
    VCID: 3E794F5C10EC
    Part No SW: 6R0 959 801 R HW: 6R0 959 801 R
    Component: J386__TSG_FT 006 0903
    Coding: 18BC30
    Part No SW: 6R0 959 802 T HW: 6R0 959 802 T
    Component: J387__TSG_BT 006 0902
    Coding: 08BC30
    Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
    Component: J388__TSG_HL 006 0902
    Coding: 08BC32
    Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
    Component: J389__TSG_HR 006 0902
    Coding: 08BC32
    2 Faults Found:
    03428 - Activation of Left Adaptive Light
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 100
    Mileage: 29674 km
    Time Indication: 0
    Date: 2098.14.28
    Time: 19:06:47
    03429 - Activation of Right Adaptive Light
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 100
    Mileage: 29674 km
    Time Indication: 0
    Date: 2098.14.28
    Time: 19:06:47
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087 D
    Component: GW-K-CAN TP20 0207
    Coding: 002200
    VCID: F0E521649A38
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 28870 km
    Time Indication: 0
    Date: 2097.14.17
    Time: 16:36:53
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 154
    Time Indication: 0
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 D HW: 1T0 035 680 B
    Component: RNS-MID H04 3810
    Revision: AB001001 Serial number: VWZ6Z7J5106024
    Coding: 0E010400040000920000
    Shop #: WSC 08441 264 91163
    ASAM Dataset: ------------------------- ------
    VCID: 2F676218C786
    1 Fault Found:
    00857 - CD Changer Unit (R41)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 30736 km
    Time Indication: 0
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    VCID: 2F676218C786
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 30736 km
    Time Indication: 0
    Re: R: Lettura diagnosi vag...
    da claudio-dj » lunedì 6 maggio 2013, 10:35
    Hai installato anche tu un rns giusto? E probabilmente lo hai preso pure usato....perché l'attuale coding non è compatibile con la tua auto...mi confermi?
    crime26
    nome: Gioacchino
    da crime26 » lunedì 6 maggio 2013, 13:19
    claudio-dj ha scritto:Hai installato anche tu un rns giusto? E probabilmente lo hai preso pure usato....perché l'attuale coding non è compatibile con la tua auto...mi confermi?
    Si..si... confermo :023
    da claudio-dj » lunedì 6 maggio 2013, 13:21
    Allora devi configurare il long coding del nav sulle attuali predisposizioni della tua auto,perchè probabilmente era installato precedentemente su di un auto con altre predisposizioni che la tua attualmente non ha,oltre ovviamente all'attivazione del modulo navigation nella Can gateway come descritto pochi post prima...
    Mentre per l'errore nella centrale,io credo che siano le luci adattive che forse hai cercato di attivare :017
    Cominciamo a risolvere una cosa per volta e vediamo cosa succede! :017
    crime26
    nome: Gioacchino
    da crime26 » lunedì 6 maggio 2013, 13:33
    claudio-dj ha scritto:Allora devi configurare il long coding del nav sulle attuali predisposizioni della tua auto,perchè probabilmente era installato precedentemente su di un auto con altre predisposizioni che la tua attualmente non ha,oltre ovviamente all'attivazione del modulo navigation nella Can gateway come descritto pochi post prima...
    :017 ....Help.... mi potresti spiegare come configurarlo?.... per quanto riguarda nell'attivazione credo di aver capito, ho provata anche a farla ma nn mi da il bit37 per poterla attivare.
    Per luci adattive cosa intendi? le diurne nei fendinebbia (che nn'ho) o le luci di svolta (che nn'ho), xkè probabilmente così è stato, ma poi ho rimesso a posto tutto e riavviato la scansione.
    da claudio-dj » lunedì 6 maggio 2013, 13:42
    In primis bisognerebbe ricordare a tutti che prima di smanettare col vag,bisognerebbe salvarsi l'attuale codifica in modo da riportare sempre la vettura alle impostazioni originali,onde evitare danni e non ricordare più le impostazioni originali...detto ciò,strano che non ci sia il modulo 37 nella lista della CAN...ci dovrebbero essere sempre tutti presenti in lista per poi attivare quello che realmente presente in vettura...Quindi vedi bene!!!Sempre che hai capito di quale lista parlo...secondo,per le luci adattive parlavo proprio di quelle di svolta...e dai bene un'occhiata che probabilmente non hai rimesso tutto bene tra i bit...
    Per la codifica del nav,entra nel modulo 37 navigation,e vedi tra i vari bit...il primo errore è il caricatore CD,che sulla tua auto non dovrebbe essere presente e che quindi devi disattivare...magari Albert che si trova già ad operare sulla sua vettura ci può postare il suo long coding del nav così da fare molto più velocemente...
    crime26
    nome: Gioacchino
    da crime26 » lunedì 6 maggio 2013, 13:51
    claudio-dj ha scritto:In primis bisognerebbe ricordare a tutti che prima di smanettare col vag,bisognerebbe salvarsi l'attuale codifica in modo da riportare sempre la vettura alle impostazioni originali,onde evitare danni e non ricordare più le impostazioni originali...detto ciò,strano che non ci sia il modulo 37 nella lista della CAN...ci dovrebbero essere sempre tutti presenti in lista per poi attivare quello che realmente presente in vettura...Quindi vedi bene!!!Sempre che hai capito di quale lista parlo...secondo,per le luci adattive parlavo proprio di quelle di svolta...e dai bene un'occhiata che probabilmente non hai rimesso tutto bene tra i bit...
    :010 Scisami.... figura di m.....a, dato che oggi è lunedì, si è ancora presi dalla sbornia della domenica :003 . Ho fatto una confusione enorme. Allora il modulo 37 c'è...
    da claudio-dj » lunedì 6 maggio 2013, 13:53
    Ecco lo sapevo!!! :010
    crime26
    nome: Gioacchino
    da crime26 » lunedì 6 maggio 2013, 14:01
    claudio-dj ha scritto:Ecco lo sapevo!!! :010
    Quindi per il long coding...? quale devo prendere per configurarlo? grazie..
    da claudio-dj » lunedì 6 maggio 2013, 15:01
    Questo dovrebbe essere quello di albert....sostituiscilo al tuo attuale nel mdulo 37 navigation 04000400000000012000 e fammi sapere! :017
    Dopodiché dovresti trovarti lo stesso code nel modulo 57 Radio... :017
    E ricorda sempre di segnarti quello attuale!!!! :006
    Bachecco
    moto: SH 300
    nome: Pierfrancesco
    da Bachecco » lunedì 6 maggio 2013, 19:44
    Allora premetto che ho la macchina bloccata in garage perchè da quanto ho capito la centralina motore è entrata in protezione( recovery) e non sale più oltre i 1.500 giri poichè ho installato in cruise control e un cavo nella centralina motore si è accavallato su di un altro pin e appena ho provato ad attivare il cruise la macchina ha decellerato di colpo.
    questa è la mia scansione AIUTATEMI :056
    VCDS Version: Release 10.6.5
    Data version: 20110930
    Monday,06,May,2013,21:20:13:37412
    Chassis Type: 6N0
    Scan: 01 03 08 09 10 15 17 19 25 37 44 55 56 77 0B
    VIN: WVWZZZ6RZBY277278
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    37-Navigation -- Status: Malfunction 1010
    55-Xenon Range -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine (J623-CGPA) Labels: None
    Part No SW: 03E 906 019 B HW: 03E 906 019 B
    Component: SIMOS11.1 H03 9878
    Revision: --H03--- Serial number:
    Coding: 00110016000400080000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM12MPI02103E906019B 001011
    ROD: EV_ECM12MPI02103E906019B.rod
    VCID: 234F9E289B4E
    6 Faults Found:
    6519 - Throttle Position Sensor (G69): Signal too Low
    P0122 00 [173] - Short to Ground
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 25179 km
    Date: 2000.00.00
    Time: 00:00:00
    6521 - Angle Sensor 2 for Throttle (G188): Signal Too Low
    P0222 00 [173] - Open or Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 25179 km
    Date: 2000.00.00
    Time: 00:00:00
    16895 - Crankshaft Position Sensor (G28): Malfunction
    P0335 00 [096] - Cannot Be Tested at this Time
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 25179 km
    Date: 2023.14.30
    Time: 00:03:53
    11407 - EVAP Purge Control Valve (N80): Circuit Malfunction
    P0443 00 [101] - Cannot Be Tested at this Time
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 25179 km
    Date: 2023.14.30
    Time: 00:01:29
    16714 - Sensor Reference Voltage A: Circuit: Low
    P0642 00 [032] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 25179 km
    Date: 2023.14.30
    Time: 00:03:53
    16713 - Sensor Reference Voltage A: Circuit: High
    P0643 00 [032] - Open or Short to Ground
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 25179 km
    Date: 2023.14.30
    Time: 00:03:51
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
    Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Coding: 210224E3217400B9842724E984D900401100
    VCID: 87176AB88FB6
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 0
    Fault Frequency: 7
    Reset counter: 9
    Mileage: 25179 km
    Time Indication: 0
    Date: 2023.14.30
    Time: 00:03:51
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x0000
    Hex Value: 0x1207
    Hex Value: 0x13B4
    Hex Value: 0x217F
    Hex Value: 0x7F7F
    Hex Value: 0x81F8
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
    Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
    Component: Man AC 02 0101
    Revision: 0002S 02
    VCID: 32616B6CD4B4
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
    Part No SW: 7H0 937 089 D HW: 7H0 937 089
    Component: BCM T5GP Li4 H47 0230
    Revision: BS047001 Serial number: 0398 078111260
    Coding: 3CB02BBF08A10000003808B17C2B0DD15AC8670F60051041200000000000
    VCID: 37775A783FD6
    Coding: 18BC30
    Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD
    Component: J387__TSG_BT 007 1611
    Coding: 08BC30
    Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
    Component: E221__MFL-TAS H07 0013
    Coding: 020000
    Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 007 1611
    Coding: 08BC32
    Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 007 1611
    Coding: 08BC32
    3 Faults Found:
    03430 - Terminal 30 for Turn Signals and Brake Lights
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 25179 km
    Time Indication: 0
    Date: 2023.14.30
    Time: 00:00:00
    03435 - Terminal 30 for Interior Light and Parking Light
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 18
    Reset counter: 9
    Time Indication: 0
    00907 - Intervention load Management
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 225
    Mileage: 25179 km
    Time Indication: 0
    Date: 2023.14.30
    Time: 01:45:58
    Address 10: Park/Steer Assist
    Cannot be reached
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag022 H09 0020
    Revision: -------- Serial number: 003GX00HMGR5
    Coding: 003232
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW25.rod
    VCID: 4A91138C5C24
    Driver's Airbag Crash Sensor:
    Serial number: 3575HRB40570DUOG79P0
    Passenger Side Airbag Crash Sensor:
    Serial number: 3585HRB40590DUOG2PB0
    Driver's Rear Airbag Crash Sensor:
    Serial number: 3515RRB404R0H1GGCGT6
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 3525RRB404T0H1GGC89O
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 860 F HW: 6R0 920 860 F
    Component: KOMBI H05 0304
    Serial number: 00000000000000
    Coding: 140E00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
    ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
    VCID: 37775A783FD6
    Part No SW: 6N0 909 901 HW: 7H0 937 089
    Component: GW-K-CAN TP20 0230
    Coding: 002200
    VCID: F0E521649A38
    4 Faults Found:
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 1
    Time Indication: 0
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 24736 km
    Time Indication: 0
    Date: 2023.14.13
    Time: 16:00:00
    01300 - Control Module for Navigation with CD-Rom (J401)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 24736 km
    Time Indication: 0
    Date: 2023.14.13
    Time: 16:00:00
    03075 - Parallel Parking Assistance Control Module (J791)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 23508 km
    Time Indication: 0
    Date: 2021.14.27
    Time: 08:36:25
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0304
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
    VCID: EAD1330CBCE4
    Part No SW: 1T0 035 680 F HW: 1T0 035 680 F
    Component: RNS-MID H55 3970
    Revision: AB001001 Serial number: VWZ6Z7L9185093
    Coding: 04000402040000900005
    Shop #: WSC 01357 011 00200
    VCID: 31636460D1B2
    5 Faults Found:
    00876 - Treble Speaker Rear Left (R14)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 4
    Mileage: 24592 km
    Time Indication: 0
    00877 - Treble Speaker Rear Right (R16)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 4
    Mileage: 24592 km
    Time Indication: 0
    00856 - Radio Antenna
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 24736 km
    Time Indication: 0
    00821 - Antenna 2 for Radio (R93)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 24736 km
    Time Indication: 0
    01523 - Microphone for Telephone (R38)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 178
    Reset counter: 9
    Mileage: 23508 km
    Time Indication: 0
    Date: 2021.14.27
    Time: 08:36:23
    Address 44: Steering Assist Labels: 6Q0-423-156.lbl
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11250
    Shop #: WSC 00788
    VCID: 2F676218C786
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 6R0 907 357 HW: 6R0 907 357
    Component: LWR-ECU H02 0070
    Revision: -------- Serial number: --------------
    Coding: 0110000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
    ROD: EV_HeadlRegulVWLWRPt_VW25.rod
    VCID: F7F71A78FF56
    VCID: 31636460D1B2
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 4
    Mileage: 24592 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 4
    Mileage: 24592 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 24736 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 232
    Mileage: 24736 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Reset counter: 9
    Mileage: 23508 km
    Time Indication: 0
    Date: 2021.14.27
    Time: 08:36:23
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
    Component: TELEFON H15 3200
    Revision: 1B001001 Serial number: 00007663112816
    Coding: 0400000000010110
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_VW25.rod
    VCID: 3B7F464803FE
    6 Faults Found:
    9455635 - Telephone Microphone
    B1048 13 [008] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 232
    9457427 - Negative output audio channel for speech/telephone
    B104F 13 [008] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 232
    9457171 - Positive output audio channel for speech/telephone
    B104E 13 [008] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 232
    12670208 - No Communication with Instrument Cluster
    U0155 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 232
    12718592 - Steering Column Control Module: No Communications
    U0212 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    0022 - Radio: No Communication
    U1066 00 [008] - Short to Plus
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 232
    Address 0B: Sec. Air Heating
    Cannot be reached
