Lettura diagnosi vag...
  • omega22
    Auto posseduta: POLO 1.6 TDI
    nome: Fabio
    Re: Lettura diagnosi vag...
    da omega22 » martedì 4 dicembre 2012, 20:11
    Ho fatto per la prima volta Autoscan e mi trova i seguenti errori chi mi aituta a capire cosa sono e se sono gravi?
    Mi preoccupa ABS, perchè in effetti la macchina ha una frenata che non mi piace...pedale gommoso e frenata lunga...
    Ho un dubbio ma la mappatura della centralina e la prova al banco possono dare questi errori?
    Chassis Type: 6N0
    Scan: 01 03 08 09 10 15 17 19 25 44 56
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: Not registered 0011
    Address 01: Engine (J623-CAYB) Labels: None
    Part No SW: 03L 906 023 MA HW: 03L 907 425 B
    Component: 1,6l R4 CR td H33 8849
    Revision: --H33--- Serial number:
    Coding: 00114016002400080000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM16TDI02103L906023MA 003004
    ROD: EV_ECM16TDI02103L906023MA.rod
    VCID: 71E3A460A0B2056
    No fault code found.
    Readiness: 1000 0000
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0002
    Revision: --------
    Coding: 210228E3417100B2842A14EA82D600421300
    VCID: 800571A417189CE
    5 Faults Found:
    01683 - Wheel Speed Signals / Vehicle Speed
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 49
    Mileage: 9078 km
    Time Indication: 0
    Date: 2011.14.22
    Time: 14:39:55
    Freeze Frame:
    Hex Value: 0x000B
    Hex Value: 0x0002
    Hex Value: 0x12FB
    Hex Value: 0x3EB3
    Hex Value: 0x0C7F
    Hex Value: 0x7F7F
    Hex Value: 0x7EF9
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 49
    Mileage: 9078 km
    Time Indication: 0
    Date: 2011.14.22
    Time: 14:40:04
    Freeze Frame:
    Hex Value: 0x400A
    Hex Value: 0x0002
    Hex Value: 0x3246
    Hex Value: 0x08B2
    Hex Value: 0x1E7F
    Hex Value: 0x7F7F
    Hex Value: 0x7D01
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 49
    Mileage: 9078 km
    Time Indication: 0
    Date: 2011.14.22
    Time: 14:40:04
    Freeze Frame:
    Hex Value: 0x400A
    Hex Value: 0x0002
    Hex Value: 0x3246
    Hex Value: 0x09B2
    Hex Value: 0x1E7F
    Hex Value: 0x7F7F
    Hex Value: 0x7D01
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 49
    Mileage: 9085 km
    Time Indication: 0
    Date: 2011.14.22
    Time: 15:33:49
    Freeze Frame:
    Hex Value: 0x0003
    Hex Value: 0x0002
    Hex Value: 0x12FD
    Hex Value: 0x259E
    Hex Value: 0x007F
    Hex Value: 0x7F7F
    Hex Value: 0x7DF9
    00778 - Steering Angle Sensor (G85)
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 50
    Mileage: 9085 km
    Time Indication: 0
    Date: 2011.14.22
    Time: 15:50:33
    Freeze Frame:
    Hex Value: 0x0003
    Hex Value: 0x0002
    Hex Value: 0x1240
    Hex Value: 0x1BB3
    Hex Value: 0x2E7F
    Hex Value: 0x7F7F
    Hex Value: 0x7EF9
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
    Component: Climatronic H11 0711
    Revision: V0000000
    VCID: 387559448B4894E
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 49
    Mileage: 9085 km
    Time Indication: 0
    Date: 2011.14.22
    Time: 15:33:54
    Part No SW: 6R0 937 087 K HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0251
    Revision: BF046001 Serial number: 0434 309110202
    Coding: 24B02BBF08A10000003008006D2B0CD00080412F60860000200000000000
    Shop #: WSC 124697 483 00190
    VCID: 458B20B0CCBAF96
    Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 008 1611
    Coding: 18BC30
    Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
    Component: J387__TSG_BT 008 1611
    Coding: 08BC30
    Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 008 1611
    Coding: 08BC32
    Subsystem 4 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Coding: 08BC32
    Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
    Part No SW: 6R0 919 475 C HW: 7E0 919 475
    Component: PARKHILFE 4K H11 0013
    Revision: -------- Serial number: 47301129501882
    Coding: 108001
    ASAM Dataset: EV_VW250ParkiAssis2 S01008
    ROD: EV_VW250ParkiAssis2.rod
    VCID: 3E794F5CA16CAAE
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag022 H09 0020
    Revision: -------- Serial number: 003GX00ZFK6%
    Coding: 003232
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW25.rod
    VCID: 4A91138CEDA416E
    Crash sensor for side airbag; driver side:
    Serial number: 3575HRB405N0U20SEH8Y
    Crash sensor for side airbag; passenger side:
    Serial number: 3585HRB405L0U20SA9BO
    Crash sensor for side airbag; rear driver side:
    Serial number: 3515RRB40610R8AAE9OK
    Crash sensor for side airbag; rear passenger side:
    Serial number: 3525RRB40610R8AADPMY
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
    Component: KOMBI H04 0206
    Serial number: 00000009517791
    Coding: 140A01
    ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
    ROD: EV_DashBoardUDSJCIPQ25_VW25.rod
    VCID: 3A71434CBD4486E
    1 Fault Found:
    12648448 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 49
    Mileage: 9085 km
    Date: 2011.14.22
    Time: 15:33:49
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H46 0251
    Revision: BF046001
    Coding: 002200
    VCID: F0E5216423B88CE
    2 Faults Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 49
    Mileage: 9085 km
    Time Indication: 0
    Date: 2011.14.22
    Time: 15:33:50
    Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
    Component: IMMO H04 0014
    Serial number:
    ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
    ROD: EV_ImmobUDSJCIPQ25_VW25.rod
    Address 44: Steering Assist Labels: 6Q0-423-156.lbl
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11230
    Shop #: WSC 00788
    VCID: 2F676218EA06536
    1 Fault Found:
    49-10 - No Communications - Intermittent
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 HW: 3C8 035 195
    Component: Radio RCD510 036 0130
    Revision: 00000001 Serial number: VWZ1Z3I4257350
    Coding: 0500040004
    Shop #: WSC 01357 011 00200
    VCID: E5CB4030EC7A596
    1 Fault Found:
    00821 - Antenna 2 for Radio (R93)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 60
    Mileage: 1048575 km
    Time Indication: 0
  • omega22
    nome: Fabio
    da omega22 » giovedì 6 dicembre 2012, 10:14
    Forse ho risolto, ho cancellato tutto e ho rifatto autoscan e sono spariti quasi tutti, mi resta solo l'autoradio non registrata perchè comprata su ebay, adesso devo provare a registrarla.
    cri89
    da cri89 » sabato 22 dicembre 2012, 22:31
    Allora ho fatto una disgnosi, dico subito che a volte quando accendo mi si accendono le 3 spie gialle abs, esp e ruote.
    Dalla diagnosi risulta che ce l'abs che è in malfunzionamento, possibile che non mi son accorto di nulla andando in giro?
    Ditemi se il resto è ok:
    Saturday,22,December,2012,23:22:45:37412
    VCDS Version: Release 10.6.5 (x64)
    Data version: 20110930
    Chassis Type: 6N0
    Scan: 01 02 03 08 09 15 17 19 25 44 55 56 0B
    VIN: WVWZZZ6RZCY506860
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Part No SW: 03L 906 023 MG HW: 03L 907 425 B
    Component: 1,6l R4 CR td H33 8847
    Coding: 00254016000400080000
    ASAM Dataset: EV_ECM16TDI02103L906023MG 003005
    ROD: EV_ECM16TDI02103L906023MG.rod
    VCID: 77F79A787F56
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 0AM-300-04x.lbl
    Part No SW: 0AM 300 052 F HW: 0AM 927 769 D
    Component: GSG DSG AG7 421 2710
    Revision: 00042014 Serial number: CU501106115638
    Coding: 0000020
    Shop #: WSC 01324 785 00200
    VCID: 2E597F1CC08C
    Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
    Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Coding: 210228E3416D00B8842D14E882D100421300
    VCID: 87176AB88FB6
    1 Fault Found:
    02214 - Tire Pressure Warning
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 9
    Reset counter: 34
    Mileage: 36155 km
    Time Indication: 0
    Date: 2015.14.23
    Time: 17:11:54
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x8000
    Hex Value: 0x1203
    Hex Value: 0x2BB8
    Hex Value: 0x567F
    Hex Value: 0x7F7F
    Hex Value: 0x8000
    Revision: V0000000
    VCID: 3875594432C8
    1 Fault Found:
    00457 - Control Module for Network (J519)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 42
    Mileage: 35602 km
    Time Indication: 0
    Date: 2015.14.06
    Time: 07:21:19
    Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
    Part No SW: 7H0 937 089 F HW: 7H0 937 089
    Component: BCM T5GP Li4 H50 0251
    Revision: BS050001 Serial number: 0465 165110638
    Coding: 24B029BF08A10000082008916C2B0DD05A00672F60051041200000010000
    VCID: 39735C4009C2
    Component: J386__TSG_FT 008 1621
    Coding: 08BC30
    Component: J387__TSG_BT 008 1621
    Coding: 08BC30
    Part No SW: 6R0 959 591 A HW: 7P0 959 591
    Component: J245 PS72.016 H07 0006
    Coding: 081001
    Component: VW10Airbag01S H09 0020
    Revision: -------- Serial number: 003GX00PNB3S
    Coding: 003153
    VCID: 4A91138C5C24
    Driver's Airbag Crash Sensor:
    Serial number: 3575HRB405V0INGS30H5
    Passenger Side Airbag Crash Sensor:
    Serial number: 3585HRB40690H4DK3H2%
    Driver's Rear Airbag Crash Sensor:
    Serial number: 3515RRB40610KOIA6GJV
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 3525RRB404R0KOIAI1A1
    Component: KOMBI H03 0505
    Serial number: 00000000000000
    Coding: 140E01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
    ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
    VCID: 3A71434C0CC4
    Part No SW: 6N0 909 901 HW: 7H0 937 089
    Component: GW-K-CAN TP20 H50 0251
    Revision: BS050001
    Coding: 002000
    VCID: F0E521649A38
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0505
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
    VCID: EAD1330CBCE4
    Coding: 11230
    Shop #: WSC 00788
    VCID: 2F676218C786
    Address 55: Xenon Range (J431) Labels: None
    Part No SW: 6R0 907 357 HW: 6R0 907 357
    Component: LWR-ECU H02 0070
    Revision: -------- Serial number: --------------
    Coding: 0110000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
    ROD: EV_HeadlRegulVWLWRPt_VW25.rod
    VCID: F7F71A78FF56
    Part No SW: 3C8 035 195 F HW: 3C8 035 195 F
    Component: Radio RCD510 052 0208
    Revision: 00000001 Serial number: VWZ1Z3L1516149
    Coding: 05000400020001
    VCID: 2B5F7608F39E
    Address 0B: Sec. Air Heating
    Cannot be reached
    wizard86pz
    moto: 1.6 TDI (90 cv)
    nome: André
    da wizard86pz » domenica 23 dicembre 2012, 12:46
    cri89 ha scritto:Allora ho fatto una disgnosi, dico subito che a volte quando accendo mi si accendono le 3 spie gialle abs, esp e ruote.
    Questo è normale ad ogni accensione del quadro. Se ti si accendono mentre sei in movimento allora è un altro conto ed è problematico.
    cri89 ha scritto:Dalla diagnosi risulta che ce l'abs che è in malfunzionamento, possibile che non mi son accorto di nulla andando in giro?
    C'è un malfunzionamento anche nel modulo "Auto HVAC" che è quello del climatizzatore.
    cri89 ha scritto:Address 03: ABS Brakes (J104) Labels: 6J0-907-37x-ESP.clb
    Revision: --------
    VCID: 87176AB88FB6
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 9
    Reset counter: 34
    Mileage: 36155 km
    Time Indication: 0
    Date: 2015.14.23
    Time: 17:11:54
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x8000
    Hex Value: 0x1203
    Hex Value: 0x2BB8
    Hex Value: 0x567F
    Hex Value: 0x7F7F
    Hex Value: 0x8000
    http://wiki.ross-tech.com/wiki/index.php/02214
    Prova a resettare il sensore di pressione dei pneumatici.
    cri89 ha scritto:Address 08: Auto HVAC (J255) Labels: None
    Revision: V0000000
    VCID: 3875594432C8
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 42
    Mileage: 35602 km
    Time Indication: 0
    Date: 2015.14.06
    Time: 07:21:19
    http://wiki.ross-tech.com/wiki/index.php/00457
    C'è un problema di comunicazione tra questo modulo e il VAG, non sembrano esserci problemi del climatizzatore.
    cri89
    da cri89 » domenica 23 dicembre 2012, 13:12
    Be diciamo che le 2 gomme di sinistra sono un filo piu sgonfie delle altre, quindi magari è quello.. Invece per il difetto al modulo del vag come risolvo??
    wizard86pz
    nome: André
    da wizard86pz » domenica 23 dicembre 2012, 13:16
    cri89 ha scritto:Be diciamo che le 2 gomme di sinistra sono un filo piu sgonfie delle altre, quindi magari è quello.. Invece per il difetto al modulo del vag come risolvo??
    Succede principalmente per due motivi (che io sappia):
    • Sporadici ed aleatori problemi di comunicazione. In tal caso basta riprovare un paio di volte;
    • Incomaptibilità ECU della centralina. Questo caso non ha soluzione ed è frequente sulle centraline nuove, su macchine con tardo MY2011/MY2012.
    cri89
    da cri89 » domenica 23 dicembre 2012, 13:18
    È ottobre 2011 quindi possibile.. Ma cosa mi stai dicendo con imcompatibilità? Che non posso vaggare nulla??
    wizard86pz
    nome: André
    da wizard86pz » domenica 23 dicembre 2012, 13:44
    Non so specificatamente cosa si può e cosa no. Ma le ultime centraline non dando pieno accesso alla versione 10.6.4 (la più stabile e diffusa) del VAG, non tutto è modificabile e (come hai potuto sperimentare) non tutto è scansionabile per una diagnosi! Dovresti chiedere info al tuo venditore (presumo donsaimon) o aprire un thread nel forum per questo!
    cri89
    da cri89 » domenica 23 dicembre 2012, 13:48
    Be allora prima proveró a vedere cosa va e cosa no..
    Ma di release mi ha detto donsaimon di mettere la 10.6.5.
    wizard86pz
    nome: André
    da wizard86pz » domenica 23 dicembre 2012, 13:55
    cri89 ha scritto:Be allora prima proveró a vedere cosa va e cosa no..
    Ok. Io l'ho preso un anno fa e c'era la 10.6.4. Non mi sono aggiornato perché la mia Polo MY2010 dialoga perfettamente con questa versione VAG che ho.
    cri89
    da cri89 » domenica 23 dicembre 2012, 14:03
    Be guarda io cosi per cosi non saprei che release è meglio dato che non le ho mai testate.. Ora devo uscire e gia che son giu provo a levare cicalino, chiusura porte e sterzo.. Poi ti aggiorno se va.
    Ps. Sei gentilissimo ;)
    cri89
    da cri89 » domenica 23 dicembre 2012, 14:55
    Ok vaggato!! Fatti: cicalino, durezza sterzo, tergi che si fermano con l'auto, porte chiuse dopo i 15kmh e coming home.
    Funziona tutto :)
