Luchino TDI ha scritto:Questa la mia Diagnosi con il VAG...sembra tutto ok o sbaglio?!
Friday,28,September,2012,23:05:47:37412
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ7Y080512
Address 01: Engine Labels: Redir Fail!
Part No: 045 906 019 CA
Component: 1,4l R3 EDC 0000SG 8400
Coding: 00002
Shop #: WSC 00788
VCID: 56A9F7FC9897
WVWZZZ9NZ7Y080512 VWZ7Z0F4446786
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Part No SW: 6Q0 907 379 AS HW: 6Q0 907 379 AS
Component: ESP 8.0 front H05 0003
Revision: 00000000 Serial number: 00000000000000
Coding: 0002368
Shop #: WSC 00788 785 00200
VCID: 8E195F9CE0C7
Address 08: Auto HVAC Labels: None
Part No: 6Q0 907 044 E
Component: CLIMAtronic PQ24 3805
Shop #: WSC 00000 000 00000
VCID: 346D6D742EAB
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00BP BN-SG. 1S34
Coding: 09358
Shop #: WSC 00788
VCID: 3C7D455406FB
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 18 AIRBAG VW51 0P 0009
Coding: 12600
Shop #: WSC 00788
VCID: 2C5D7514F69B
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 804 K
Component: KOMBIINSTRUMENT VDO V03
Coding: 01132
Shop #: WSC 00000
VCID: 39735C4009C9
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 01K1 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
VCID: F0E521649A33
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER VDO V03
Coding: 01132
Shop #: WSC 00000
VCID: 39735C4009C9
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10150
Shop #: WSC 00788
VCID: 6FE7A218070D
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 64 Komfortgerát 0002
Coding: 00019
Shop #: WSC 00788
VCID: 3D7B48501DE1
), questi si ripresenteranno se il guasto persiste?cioè io ho resettato gli errori, non avrò tutto ok alla prossima diagnosi se l'auto ha ancora problemi, giusto? comunque credo siano partiti anche a me i motoposizionatori (a proposito, chi mi dice cosa sono precisamente?
) spero possiate aiutarmi..ciaooo grazie
beddo ha scritto:ragazzi ho comprato da poco il cavo vag e ho eseguito anche io delle diagnosi..volevo chiedervi: se io cancello gli errori (lo so, non risolvo certo il problema), questi si ripresenteranno se il guasto persiste?cioè io ho resettato gli errori, non avrò tutto ok alla prossima diagnosi se l'auto ha ancora problemi, giusto? comunque credo siano partiti anche a me i motoposizionatori (a proposito, chi mi dice cosa sono precisamente?
wizard86pz ha scritto: Da cosa sospetti che i motoposizionatori del climatizzatore siano partiti?
scusa l'ignoranza
beddo ha scritto:wizard86pz ha scritto: Da cosa sospetti che i motoposizionatori del climatizzatore siano partiti?
perchè ho letto la diagnosi in prima pagina di juanpalmy e ricordo che gli errori che mi segnalava la mia erano simili..mi sapresti spiegare cosa sono questi motoposizionatori?scusa l'ignoranza
..sai su per giu quanto mi costerebbero?
beddo ha scritto:aaaah ecco..capisco allora perchè non mi ero accorto di questo guasto..non uso molto spesso l'aria condizionata..sai su per giu quanto mi costerebbero?
nooooo penso proprio che lascio perdere allora..
comunque appena posso rifaccio la diagnosi e ve la posto..
chi mi illumina?
