Lettura diagnosi vag...
  • lorenzo999
    Auto posseduta: Polo 9N3
    nome: Lorenzo
    Re: Lettura diagnosi vag...
    da lorenzo999 » lunedì 25 giugno 2012, 9:23
    Ecco i faults rilevati dalla vaggata sulla mia polo 9N3 del 2008.
    C'è modo di risolverli fai da te?
    In particolare quelli relativi all'aria condizionata "Relay for Coolant Fan" si possono sostituire i relay?
    Per i problemi che avevo riscontrato vi rimando a questo topic:
    viewtopic.php?f=14&t=17089
    Codice: Seleziona tutto
    Friday,22,June,2012,20:15:35:10074
    VCDS Version: Beta 11.3.0
    Data version: 20110801
    Chassis Type: 9N - VW Polo
    Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
    VIN: WVWZZZ9NZ8B024415   Mileage: 42320km/26296miles
    Address 01: Engine        Labels: Redir Fail!
       Part No: 03D 906 023
       Component: SIMOS91 1.2l 2V     5413
       Revision: --H04---    Serial number: VWZ7Z0G5853125
       Coding: 0000071
       Shop #: WSC 00046 412 00000
       VCID: DBB1135F6601
    1 Fault Found:
    16726 - Camshaft Position Sensor (G40): Signal too Low
                P0342 - 009 - Open or Short to Ground - Intermittent
                 Freeze Frame:
                        RPM: 832 /min
                        Mass Air / Rev.: 103.6 mg/str
                        Bin. Bits: 00000100
                        Temperature: 93.0Í
                        RPM: 2016 /min
                        Mass Air / Rev.: 65.4 mg/str
                        Bin. Bits: 00100000
                        Temperature: 93.0Í
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS.lbl
       Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
       Component: ABS 8.0 front   H05 0002
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0002082
       VCID: 810D0137A42D
    2 Faults Found:
    01314 - Engine Control Module
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 2
                        Fault Frequency: 55
                        Reset counter: 230
                        Mileage: 41962 km
                        Time Indication: 0
    18265 - Load Signal: Error Message from ECU
                P1857 - 000 -  -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 2
                        Fault Frequency: 254
                        Reset counter: 230
                        Mileage: 36410 km
                        Time Indication: 0
    Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
       Part No: 6Q0 820 045
       Component: Klimaanlage        X0850
       VCID: EADF469BB95B
    2 Faults Found:
    00705 - Relay for Coolant Fan; Stage 1 (J279)
                31-00 - Open or Short to Ground
    00706 - Relay for Coolant Fan; Stage 2 (J513)
                31-10 - Open or Short to Ground - Intermittent
  • Friarie1992
    Auto posseduta: golf 2 e 4 serie
    nome: Antonio
    da Friarie1992 » martedì 26 giugno 2012, 11:07
    ragazzi sapete aiutarmi questa e l'auto-scan della mia macchina non funzionano i comandi al volante
    VCDS Version: Release 10.6.4 (x64)
    Data version: 20110418
    Thursday,21,June,2012,16:41:46:10074
    Chassis Type: 6N0
    Scan: 01 03 08 09 10 15 17 19 25 2E 37 44 56
    VIN: WVWZZZ6RZCY081296
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine (J623-CAYB) Labels: None
    Part No SW: 03L 906 023 MA HW: 03L 907 425 B
    Component: 1,6l R4 CR td H33 8849
    Revision: --H33--- Serial number:
    Coding: 00114016002400080000
    Shop #: WSC 00788 648 00255
    ASAM Dataset: EV_ECM16TDI02103L906023MA 003004
    ROD: EV_ECM16TDI02103L906023MA.rod
    VCID: 71EDD1F71139
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
    Component: ESP8.2i front H05 0001
    Revision: --------
    Coding: 210228E3417500B3842714EB82D700421300
    VCID: 87191F2F8FBD
    1 Fault Found:
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 158
    Mileage: 8577 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 16:28:24
    Freeze Frame:
    Hex Value: 0x0007
    Hex Value: 0x0002
    Hex Value: 0x12FD
    Hex Value: 0x259C
    Hex Value: 0x007F
    Hex Value: 0x7F7F
    Hex Value: 0x7BF9
    Address 08: Auto HVAC (J255) Labels: None
    Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
    Component: Climatronic H11 0711
    Revision: V0000000
    VCID: 387B2CD332C3
    Part No SW: 6R0 937 087 K HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0251
    Revision: BF046001 Serial number: 0434 239111139
    Coding: 3DB02BBF08A1000000380E006D6B0CD80088412F60860000200000000000
    VCID: 458555277531
    Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB
    Component: J386__TSG_FT 008 1611
    Coding: 18BC30
    Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD
    Component: J387__TSG_BT 008 1611
    Coding: 08BC30
    Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
    Component: E221__MFL-TAS H09 0013
    Coding: 020000
    Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
    Component: J388__TSG_HL 008 1611
    Coding: 08BC32
    Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
    Component: J389__TSG_HR 008 1611
    Coding: 08BC32
    1 Fault Found:
    00967 - Left Turn Signals
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 160
    Mileage: 8623 km
    Time Indication: 0
    Date: 2008.14.22
    Time: 10:46:47
    Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb
    Part No SW: 6R0 919 475 C HW: 7E0 919 475
    Component: PARKHILFE 4K H11 0013
    Revision: -------- Serial number: 47301122501438
    Coding: 108001
    ASAM Dataset: EV_VW250ParkiAssis2 S01008
    ROD: EV_VW250ParkiAssis2.rod
    VCID: 3E773ACB10E7
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10Airbag022 H09 0020
    Revision: -------- Serial number: 003GX00V60HK
    Coding: 003232
    ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
    ROD: EV_AirbaVW10BPAVW250_VW25.rod
    VCID: 4A9F661B5C2F
    Driver's Airbag Crash Sensor:
    Serial number: 3575HRB405R0OCUIDPAS
    Passenger Side Airbag Crash Sensor:
    Serial number: 3585HRB405R0OCUI5OJT
    Driver's Rear Airbag Crash Sensor:
    Serial number: 3515RRB405B0M98EGOP2
    Passenger's Rear Airbag Crash Sensor:
    Serial number: 3525RRB404T0MFP6HHTX
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
    Component: KOMBI H04 0206
    Serial number: 00000008534055
    Coding: 540A01
    ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
    ROD: EV_DashBoardUDSJCIPQ25_VW25.rod
    VCID: 3A7F36DB0CCF
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H46 0251
    Revision: BF046001
    Coding: 002200
    VCID: F0EB54F39A33
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 158
    Mileage: 8577 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 16:28:24
    Address 25: Immobilizer (J285) Labels: 5K0-920-xxx-25.clb
    Component: IMMO H04 0014
    Serial number:
    ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001
    ROD: EV_ImmobUDSJCIPQ25_VW25.rod
    VCID: 3A7F36DB0CCF
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Component: SG EXT.PLAYER H13 0240
    Revision: A1001003 Serial number: 7660780229
    Coding: 020000
    VCID: 295DF997F969
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 F HW: 1T0 035 680 F
    Component: RNS-MID H60 4020
    Revision: AB001001 Serial number: VWZ6Z7L3249002
    Coding: 04000202040000200011
    Shop #: WSC 00152 264 18320
    ASAM Dataset: ------------------------- ------
    VCID: 316D11F7D1B9
    3 Faults Found:
    00876 - Treble Speaker Rear Left (R14)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8576 km
    Time Indication: 0
    00877 - Treble Speaker Rear Right (R16)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8576 km
    Time Indication: 0
    01523 - Microphone for Telephone (R38)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8577 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 16:09:31
    Address 44: Steering Assist Labels: 6Q0-423-156.lbl
    Part No: 6R0 423 156 B
    Component: LenkhilfeTRW V277
    Coding: 11230
    Shop #: WSC 00788
    VCID: 2F69178FC78D
    1 Fault Found:
    49-10 - No Communications - Intermittent
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    VCID: 316D11F7D1B9
    3 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8576 km
    Time Indication: 0
    00877 - Unlicensed Version. Not all DTCs
    011 - will be decoded.
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8576 km
    Time Indication: 0
    01523 - Unlicensed Version. Not all DTCs
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 120
    Mileage: 8577 km
    Time Indication: 0
    Date: 2008.14.21
    Time: 16:09:31
    POLO 1.6 TDI 90cv highline, Nero perla,Tech & Sound Pack con rsn 510,Comfort Pack,Listello cromato vw,Marmitta cromata vw,Battitacco vw,Tappetini in gomma originali vw,Pedaliera sportiva originale vw,Luci anteriori ultra white ,Luce posizione a led,Luce targa a led,Poggiapiede golf VI,Moquette cassetti,luci interne a led.
    Modifiche via vag:blocco portiere a 15 km/h & sblocco all'estrazione della chiave,consumi in km/l,Disattivazione luci diurne
    Immagine ImmagineImmagine
    lucamatrix
    nome: lucamatrix
    da lucamatrix » mercoledì 27 giugno 2012, 17:05
    Qulacuno può darmi delucidazioni in merito agli errori del mio Autoscan:
    Wednesday,27,June,2012,16:33:29:37412
        VCDS Version: Release 11.11.3
        Data version: 20120401
        Chassis Type: 6N0
        Scan: 01 03 08 09 15 17 19 25 2E 44 55 56 0B
        VIN: WVWZZZ6RZCY********
        01-Engine -- Status: OK 0000
        03-ABS Brakes -- Status: OK 0000
        09-Cent. Elect. -- Status: OK 0000
        55-Xenon Range -- Status: OK 0000
           Coding: 00114016000400080000
           VCID: 71E3A460A0B23B1
        Address 03: ABS Brakes (J104)       Labels: 6J0-907-37x-ESP.clb
           Revision: --------
           Coding: 210228E3417500B3842E14EA82D800421300
           VCID: 87176AB83236951
           Revision: V0000000
           VCID: 387559448B48AA9
        Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
           Part No SW: 7H0 937 089 F    HW: 7H0 937 089
           Component: BCM T5GP Li4  H50 0251
           Revision: BS050001    Serial number: 0465 223110698
           Coding: 3CB02BBF08A10000003808916C2B0DD05A00672F60051041200000010000
           Shop #: WSC 12469 483 00190
           VCID: 39735C40B042B31
           Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
           Coding: 18BC30
           Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
           Coding: 08BC30
           Subsystem 3 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
           Coding: 020000
           Subsystem 4 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
           Coding: 08BC32
           Subsystem 5 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
           Coding: 08BC32
           Revision: --------    Serial number: 003GX00V5ECS
           Coding: 003232
           VCID: 4A91138CEDA4289
           Crash sensor for side airbag; driver side:
           Serial number: 3575HRB405T0Q3SKDGQU
           Crash sensor for side airbag; passenger side:
           Serial number: 3585HRB405V0Q3SKB8FC
           Crash sensor for side airbag; rear driver side:
           Serial number: 3515RRB40510MFP670B3
           Crash sensor for side airbag; rear passenger side:
           Serial number: 3525RRB404T0MFP6GHRU
        Address 17: Instruments (J285)       Labels: None
           Component: KOM
           Coding: 140E01
           ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
           ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
           VCID: 55ABF0F0341A771
           Part No SW: 6N0 909 901     HW: 7H0 937 089
           Component: GW-K-CAN TP20 H50 0251
           Coding: 002200
           VCID: F0E5216423B8B29
        1 Fault Found
        00470 - Combination comfort Databus in Single Wire
                    012 - Electrical Fault in Circuit
                     Freeze Frame:
                            Fault Status: 01101100
                            Fault Priority: 2
                            Reset counter: 235
                            Mileage: 4121 km
                            Time Indication: 0
                            Date: 2004.14.16
                            Time: 10:15:38
        Address 25: Immobilizer (J334)       Labels: Redir Fail!
           Part No SW: 5K0 953 234     HW: 5K0 953 234
           Component: IMMO          H03 0505
           Serial number:
           Coding: 000000
           Shop #: WSC 00000 000 00000
           ASAM Dataset: EV_ A03009
           ROD: N/A
           VCID: EAD1330C0D64489
        No ASAM data for: "EV_" (VW25)
           Coding: 010000
           VCID: 29538C0040E2031
           Coding: 11210
           Shop #: WSC 00788
           VCID: 2F676218EA066D1
        Address 55: Xenon Range (J431)       Labels: None
           Part No SW: 6R0 907 357     HW: 6R0 907 357
           Component: LWR-ECU       H02 0070
           Revision: --------    Serial number: --------------
           Coding: 0110000000000000
           ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
           ROD: EV_HeadlRegulVWLWRPt_VW25.rod
           VCID: F7F71A784ED6E51
        Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
           Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
           Component: Radio RCD310  031 0075
           Revision: 01000001    Serial number: VWZ1Z2L3509432
           Coding: 01000400020001
           VCID: 336F6E68922E491
        1 Fault Found
        00856 - Radio Antenna
                    011 - Open Circuit
                     Freeze Frame:
                            Fault Priority: 5
                            Fault Frequency: 1
                            Reset counter: 116
                            Mileage: 8656 km
                            Time Indication: 0
                            Date: 2007.14.18
                            Time: 09:03:45
        Address 0B: Sec. Air Heating
        Cannot be reached
    Grazie in anticipo... :023
    Ultima modifica di lucamatrix il venerdì 29 giugno 2012, 22:06, modificato 1 volta in totale.
    Immagine Immagine Immagine
    Manuel91
    Auto posseduta: Highline 1.6 tdi
    moto: Cagiva mito
    nome: Manuel
    da Manuel91 » giovedì 28 giugno 2012, 16:47
    Ragazzi vi prego aiuto ! cosa significa questo errore ? è qualcosa di grave? grazieee
    Revision: BS050001 Serial number: 0465 251111033
    Coding: 24B02BBF08A10000003808916C2B0DD05A80672F60051041200000010000
    VCID: 39735C4009C9
    Coding: 18BC30
    Coding: 08BC30
    Coding: 020000
    Coding: 08BC32
    Coding: 08BC32
    2 Faults Found:
    03431 - Activation of Left Parking Light
    006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00100110
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 58
    Mileage: 10744 km
    Time Indication: 0
    Date: 2008.14.07
    Time: 17:55:15
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 2
    Fault Frequency: 175
    Reset counter: 58
    Time Indication: 0
    boomshakalaka
    da boomshakalaka » martedì 17 luglio 2012, 22:29
    Anche a me fa una cosa simile ma solo sulla posizione... se tiro la manopolina leggermente verso di me per ora si sistema tutto... nelle altre posizioni non ho problemi... tu come hai risolto?
    Manuel91
    moto: Cagiva mito
    nome: Manuel
    da Manuel91 » mercoledì 18 luglio 2012, 7:37
    boomshakalaka ha scritto:Anche a me fa una cosa simile ma solo sulla posizione... se tiro la manopolina leggermente verso di me per ora si sistema tutto... nelle altre posizioni non ho problemi... tu come hai risolto?
    Io ho cancellato l'errore.. Perche non ho capito di cosa si tratta ! Tu hai capito?
    boomshakalaka
    da boomshakalaka » mercoledì 18 luglio 2012, 8:48
    Ah non ho potuto fare la diagnosi perchè non hoil vag... Io pensavo di cambiare solo l'interruttore..
    Manuel91
    moto: Cagiva mito
    nome: Manuel
    da Manuel91 » mercoledì 18 luglio 2012, 10:30
    boomshakalaka ha scritto:Ah non ho potuto fare la diagnosi perchè non hoil vag... Io pensavo di cambiare solo l'interruttore..
    Ma come fai a sapere che il problema riguarda la manopolina ?
    boomshakalaka
    da boomshakalaka » mercoledì 18 luglio 2012, 11:39
    Nel mio caso se quando sono sulla posizione la tiro leggermente verso di me fino a farle fare uno scattino si sistema... sembra proprio un problema di contatti.. non so la tua come fa...?
    fede71
    Auto posseduta: polo 6r 1.2 comf.
    moto: bmw f650gs twin
    nome: federico
    da fede71 » martedì 21 agosto 2012, 20:49
    Cari signori......
    oggi mi sono cimentato con il vcds 11.11.4 e cavo originale (sì, sono matto ma sono fatto così)
    come eseguo l'autoscan ogni volta il test si blocca sul modulo 56 (radio) e non ci sono santi se non chiudere brutalmente il programma.
    Ora, ho una polo 1.2 conf. mod. 2012 con una radio Telefunken AS 9090 che sfrutta il collegamento fakra originale senza modifiche sui cavi.......
    Che sia questa che crea il problema?
    è possibile eliminare il modulo 56 dall'autoscan?
    Un'ultima cosa..... ho visto che a molti non è funzionata l'attivazione del tear wiping ritardato (error coding 31)...... soluzioni?
    grazie per la pazienza... :006
    Federico ride on Polo 1.2 Confortline nero perla, 5 porte, fendinebbia e basta
    also ride on
    Bmw F650GS Twin "Evenstar"
    ciamardo
    nome: Principe
    da ciamardo » mercoledì 22 agosto 2012, 12:50
    fede71 ha scritto:Cari signori......
    ciao allora di matti siamo due :) comunque se vuoi delle risposte concrete fai un autoscan quello che viene fuori e lo spedisci al supporto ross-tech descrivendo il problema e piu eventuali tipo il tear wiping! di solito ti rispondono in 2 giorni! facci sapere ciao
    !!!VAGgo è sono felice!!!
    VCDS Wi-Fi HEX-NET :033
    Ggalez
    Auto posseduta: Polo 6r 1.6TDI
    nome: Giulio
    da Ggalez » venerdì 24 agosto 2012, 18:45
    Cos'è che non va? Non riesco a vaggare per installare il cruise...
    Thursday,23,August,2012,20:56:26:37412
    Chassis Type: 6N0
    Scan: 01 03 08 09 15 17 19 25 44 56
    VIN: WVWZZZ6RZCY087601
    01-Engine -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
       Shop #: WSC 80021 264 91185
       VCID: 71E3A4601139
    1 Fault Found:
    6117 - Function Restriction due to Implausible Message(s)
              U1112 00 [045] - No or Incorrect Basic Setting / Adaptation
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 3
                        Mileage: 20154 km
                        Date: 2009.14.27
                        Time: 11:04:10
       Revision: --------
       Coding: 210228E3417500B9842B14E282D200421100
       VCID: 87176AB88FBD
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045.clb
       Part No SW: 6R0 820 045 G    HW: 6R0 820 045 G
       Component: Man AC         02 0101
       Revision: 0002S 02
       VCID: 32616B6CD4BF
       Revision: BF046001    Serial number: 0434 211110571
       Coding: 3CB02BBF08A10000003008006D2B0CD00020412F60860000200000000000
       VCID: 458B20B07531
       Coding: 18BC30
       Coding: 08BC30
       Coding: 08BC32
       Coding: 08BC32
    1 Fault Found:
    01331 - Door Control Module; Driver Side (J386)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 31
                        Time Indication: 0
       Component: VW10Airbag01M H09 0020
       Revision: --------    Serial number: 003GX00V68BM
       Coding: 00314D
       VCID: 4A91138C5C2F
       Serial number: 3575HRB405J0Q3SKGGVS
       Serial number: 3585HRB405H0Q3SKBPMM
       Serial number: 3515RRB40550NS9QG1N4
       Serial number: 3525RRB40550NS9Q2P1-
       Serial number: 00000008832724
       Coding: 140200
       VCID: 3A71434C0CCF
    VW Polo 1.6TDI Comfortline
    5 Porte, interni chiari
    Argento Riflesso
    Cerchi 15" Sima
    RCD 310
    Bracciolo Originale VW
    Cruise Control
    -Blocco portiere oltre i 15km/h
    -Sblocco portiere alla rimozione chiave
    -Fendinebbia con funzione cornering
    -Avvisatore cinture Off
