)Codice: Seleziona tutto
VAG-COM Version: Release 311.2-N
Chassis Type: 9N1 - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 03E 906 033
Component: 1,2l/4V SIMOS3 00HS7000
Coding: 00071
Shop #: WSC 30122
WVWZZZ9NZ3Y024856 VWZ7Z0B5177682
2 Faults Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
Readiness: 0010 0101
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 00788
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08 -------------------------------------------------------
Controller: 6Q0 820 045
Component: Klimaanlage X0840
1 Fault Found:
01271 - Positioning Motor for Temperature Flap (V68)
55-00 - Adaptation Not Successful
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S32
Coding: 25742
Shop #: WSC 00788
No fault code found.
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Q0 920 800 P
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 01131
Shop #: WSC 00000
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 00 GATEWAY CAN 1S32
Coding: 00014
Shop #: WSC 00788
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 00788
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 H
Component: 1G Komfortgerát 0001
Coding: 00067
Shop #: WSC 00788
End -------------------------------------------------------
XxXDoMeNiKoXxx ha scritto:errore nello scan con vag
vi riporto il risultato dello scan della centralina
Address 09:6R0 937 088 channel 43 adapted from 3 to 5 Saturday,30,July,2011,16:08:55:36838
questa è la stringa iniziale che identifica la centralina...
Coding: 00071
Shop #: WSC 30122
4 Faults Found:
P0130 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17811 - EGR System: Regulation Divergence
P1403 - 35-10 - - - Intermittent
Readiness: 0010 0001
Coding: 0001097
Shop #: WSC 00788
4 Faults Found:
29-00 - Short to Ground
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to B+ - Intermittent
41-10 - Blocked or No Voltage - Intermittent
Coding: 25742
Shop #: WSC 00788
Coding: 01131
Shop #: WSC 00000
2 Faults Found:
01128 - Immobilizer Pickup Coil (D2)
01176 - Key
07-10 - Signal to Low - Intermittent
Coding: 00014
Shop #: WSC 00788
Coding: 00140
Shop #: WSC 00788
Coding: 00067
Shop #: WSC 00788
Lo scopo fondamentale della Egr (Exaust Gas Ricircolation) è quello di ridurre l’inquinamento facendo ricircolare parte dei gas di scarico per abbattere gli ossidi di azoto in uscita verso la marmitta.
Fin qui tutto bello e perfetto e lo schema è semplice:
Valvola EGR: come funzionaSi spilla una parte dei gas di scarico dal collettore, tramite una valvola lo si invia eventualmente ad un piccolo scambiatore che lo raffredda e poi lo invia al collettore di aspirazione dove questi gas, essendo esausti, cioè senza ossigeno, non partecipano alla combustione, e quindi fanno si che la temperatura all’interno del cilindro si abbassi di quel tanto, calcolato in sede di progetto, che serve a portare gli scarichi alla percentuale desiderata gli ossidi.
A seconda delle varie condizioni di esercizio la Egr si apre o si chiude o modula.
