Troubleshooting MLB The Show 26 Crashes: PS5 Edition
  • VelvetThistle
    Auto posseduta: fjy
    nome: VelvetThistle
    da VelvetThistle » giovedì 21 maggio 2026, 8:30
    If you've been enjoying MLB The Show 26), you may have run into frustrating crashes, freezes, or sudden shutdowns on the PlayStation 5. Fortunately, most of these issues can be addressed with a mix of in-game adjustments and console-level maintenance. Here's a straightforward guide to getting back to the diamond without interruptions.
    Game-Specific Workarounds
    Certain menus and modes in MLB The Show 26 are notorious for causing freezes. These tips help you avoid the main triggers:
    Avoid Unstable Menus: Rapidly navigating Diamond Dynasty progress tabs, XP paths, collections screens, or frequently switching lineups in the Squad Builder can trigger crashes. Slow down navigation to minimize risk.
    Bypass Problematic Game Modes: If Diamond Dynasty crashes often, try accessing your Moments directly from the main game screen instead of going through multiple submenus.
    Disable Cross-Play: Turning off Cross-Play in your online settings can reduce mid-game disconnects and random crashes.
    Road to the Show Fix: Persistent season-transition crashes (like moving from AA to AAA) can sometimes be solved by logging out of your PSN account for a few minutes, then logging back in. Increasing your player's fielding attribute above 60–65 may also bypass certain script freezes.
    Console & System Optimization
    If the game keeps closing to the home screen or the PS5 powers off entirely, these system-level fixes often help:
    Check for Updates: Highlight MLB The Show 26 on the dashboard, press the Options button, and select "Check for Update." Developer patches frequently address stability issues.
    Turn Off VRR: Variable Refresh Rate (VRR) can cause frame drops and instability. Disable it in your PS5's video output settings.
    Clear Cache & Rebuild Database: Boot your PS5 into Safe Mode by holding the power button for 7 seconds until a second beep. Connect your controller via USB, then select "Clear Cache and Rebuild Database." This clears corrupted data that can cause crashes.
    Restore Licenses: Navigate to Settings > Users and Accounts > Other > Restore Licenses to resolve potential digital ownership conflicts.
    Prevent Overheating: Full shutdowns can be thermal-related. Place your PS5 horizontally, ensure proper ventilation, and use compressed air to clean dust from fans and vents.
    Close other applications while running the game to free system resources.
    Regularly restart your PS5 to maintain optimal memory performance.
    Keep your PS5 firmware up to date, as system updates often include game stability improvements.
    By combining these in-game and console-level strategies, most PS5 players can significantly reduce crashes and enjoy smoother MLB The Show 26 sessions.
