The tactical sandbox of Embark Studios’ PvPvE extraction shooter, ARC Raiders, forces players to constantly weigh risk against reward. While choosing the right firearm or armor is vital, mastering your utility items often draws the line between a successful extraction and losing all your hard-earned loot. Among these utility gadgets, the Fireworks Box stands out as a unique item that combines psychological warfare, AI manipulation, and pure flashiness.
Though it might initially look like a joke or a purely cosmetic gimmick, smart players use it to turn a chaotic battlefield completely in their favor.
What is the Fireworks Box?
The Fireworks Box is a rare, quick-use gadget weighing 0.5 kg. When deployed on a flat surface and activated remotely, it shoots a loud, dazzling display of colored lights into the sky for several seconds.
You can occasionally purchase the physical item directly from Shani for 60 credits (with a daily restock limit of 3 boxes), or you can recycle an unwanted box back into 1 Explosive Compound. However, to reliably run this item in your standard loadout, you need to unlock its recipe at Explosives Station Level 2. Crafting a single Fireworks Box requires:
1× Explosive Compound
3× Pop Triggers
Because it relies on RNG, finding the blueprint itself can be a real grind. The drop rates vary wildly across Calabretta: the Buried City offers the highest baseline drop rate at 0.93% (particularly in the Plaza Rosa Raid House Kitchens), followed by the Spaceport at 0.68%, while areas like Stella Montis sit at a tiny 0.06%. Many players prefer to skip the tedious RNG entirely and look for alternative ways to acquire these rare crafting recipes. For example, if you want to bypass the grinding entirely, you can use online player-to-player marketplaces like U4N, buy arc raiders blueprints xbox edition or PC versions, and have a veteran player drop the recipe directly into your safe pocket during a live raid.
Practical and Tactical Uses in Gameplay
Once you have a stack of Fireworks Boxes in your inventory, they serve three primary functions on the map:
1. The Ultimate Distraction and AI Bait
The most valuable mechanic of the Fireworks Box is its ability to attract both automated ARC drones and rival human players. It functions similarly to the game's rubber duckies but on a much louder, more vertical scale.
If you are pinned down by aggressive Rocketeers or a swarm of drones, you can toss a Fireworks Box in the opposite direction and activate it. The loud noises and bright flashes instantly reset the AI pathfinding, pulling the killer robots toward the display. Even better, you can deploy a box near an enemy squad’s cover. The noise will mask your footsteps, and the incoming wave of attracted ARC units will force your rivals out into the open, leaving them completely vulnerable to an ambush.
2. Visual Signaling and Counters to Severe Weather
During harsh weather dynamic events—such as a intense Cold Snap—visibility in ARC Raiders can drop by up to 80%, turning the map into a blinding white screen of snow and fog.
In these moments, a Fireworks Box acts as an emergency lighthouse. Because the fireworks shoot high above the ground terrain, teammates separated during an intense firefight can use the bursts to realign their positions. It can also serve as a pre-arranged tactical signal for coordinated squads (e.g., "pop the fireworks when the extraction vent is clear").
3. Psychological Warfare and Celebrations
Never underestimate the power of tilting your opponents. Setting off a massive firework display right next to an extraction point tells everyone nearby that you are confident, loud, and waiting. Some squads carry 4 to 5 boxes into a match purely to throw massive post-wipe celebrations after taking down a lobby boss or successfully wiping a rival trio.
Is It Worth an Inventory Slot?
With a low carry weight of 0.5 kg, the Fireworks Box doesn’t severely penalize your movement or backpack capacity. However, because it lacks direct explosive damage, it should never replace your core frag grenades or healing items.
Think of it as a specialized utility tool. In a game where sound cues and positioning dictate who survives, an item that can completely fabricate fake firefights and redirect killer robots is worth its weight in gold—even if it looks like a party trick.
