In Warborne: Above Ashes, combat is fast, aggressive, and deeply rooted in skill synergy. Among the many weapon archetypes available, axes stand out as one of the most brutal and versatile choices in the game. Designed for players who want to dominate close-range engagements, WAA Solarbite , and unleash devastating area damage, the axe toolkit offers a compelling mix of raw power and tactical utility.
This guide explores the full axe skill set, breaking down how each ability functions, how they synergize, and how players can build around them to maximize their impact in both PvE and PvP environments. Whether you're diving into large-scale battles or grinding through mobs, mastering axes can transform you into a relentless force on the battlefield.
The Identity of Axes in Warborne
Axes in Warborne: Above Ashes are not subtle weapons. They are built for aggression, disruption, and sustained pressure. Unlike more precision-focused weapons, axes thrive in chaotic engagements where positioning, timing, and crowd control matter more than surgical strikes.
The core strengths of axes include:
High AoE damage potential
Strong crowd control tools
Debuffs that weaken enemy defenses and sustain
Momentum-based combat flow
However, axes also demand commitment. Most abilities require you to be in the thick of the fight, meaning positioning errors can be punishing. The key to success lies in chaining abilities effectively and controlling the pace of combat.
Core Attack: The Foundation of Pressure
At the heart of the axe kit is the Basic Attack, dealing 130% physical damage. While it may seem straightforward, it plays a crucial role in activating passive effects and maintaining pressure between cooldowns.
This attack becomes significantly more powerful when enhanced by buffs like Rage, turning it from filler into a major source of sustained DPS. Players who underestimate their basic attacks often miss out on a large portion of their total damage output.
Skill Tier 1: Shaping Your Offensive Style
The first tier of axe skills replaces or enhances your basic attack, defining your overall combat rhythm.
Cleaving Strike
Cleaving Strike replaces your basic attack with a frontal cone attack dealing 160% damage. This is your bread-and-butter for multi-target encounters.
Best used for: Farming mobs, applying consistent AoE pressure
Strength: Reliable, spammable, efficient
Weakness: Limited burst potential
This skill is ideal for players who prefer a steady, sweeping combat style rather than burst-heavy engagements.
Jump Cleave
Jump Cleave introduces mobility and burst, allowing you to leap into enemies every 6 seconds and deal 220% damage while reducing armor by 15% for 4 seconds.
Best used for: Initiation, gap closing, burst setups
Strength: Mobility + debuff
Weakness: Requires precise timing
This is one of the most impactful skills in the axe kit. The armor reduction alone makes it invaluable in both solo and group play, amplifying not only your damage but also your allies'.
Cyclone Slash
Cyclone Slash deals 240% damage to nearby enemies every 5 seconds and reduces healing received by 15% for 4 seconds.
Best used for: Anti-healing pressure, AoE burst
Strength: Strong against sustain-heavy enemies
Weakness: Requires close proximity
In PvP, this skill can completely shut down healing-based builds, making it a must-have in competitive scenarios.
Skill Tier 2: Control, Buffs, and Battlefield Manipulation
The second tier of skills adds depth to your build, offering buffs, crowd control, and utility options.
Rage
Rage boosts your basic attacks with +20% critical rate and +35% attack speed for 9 seconds.
Best used for: Sustained DPS windows
Strength: Massive damage amplification
Weakness: No direct damage or control
Rage transforms your combat flow. When activated at the right moment, it allows you to overwhelm enemies with rapid, high-crit strikes.
Axehook
Axehook pulls up to 5 enemies toward you, dealing 200% damage and applying a 50% slow for 4 seconds.
Best used for: Crowd control, grouping enemies
Strength: Positioning manipulation
Weakness: Limited against spread-out targets
This skill is incredibly powerful in both PvE and PvP. Pulling enemies into your AoE combos can instantly swing the momentum of a fight.
Rock Smash
Rock Smash is a multi-phase attack that deals initial damage, stuns enemies for 1.25 seconds, and adds additional damage through flying and landing stones, along with a 30% slow.
Best used for: Disruption, crowd control chains
Strength: Multi-layered CC and damage
Weakness: Slightly slower execution
This is one of the most versatile skills in the axe arsenal. It not only deals solid damage but also creates openings for follow-up attacks.
Primal Rush
Primal Rush charges forward, knocking enemies back and dealing cumulative damage, with a stronger final hit.
Best used for: Engagement, displacement
Strength: Mobility + control
Weakness: Can scatter enemies unintentionally
This skill shines in chaotic fights, allowing you to disrupt formations or push enemies into unfavorable positions.
Tempest Strike
Tempest Strike is a channeled ability lasting up to 3 seconds, dealing continuous damage and ending with a powerful final strike. It also grants 25% damage resistance while channeling.
Best used for: Sustained AoE damage, tanking through pressure
Strength: High total damage + survivability
Weakness: Vulnerable to interruption
This ability rewards commitment. When used correctly, it can devastate groups of enemies while keeping you alive through incoming damage.
Skill Synergy: Building the Perfect Combo
The true power of axes comes from how these abilities interact. A well-executed combo can chain crowd control, apply debuffs, and unleash massive damage in seconds.
Example Combo (PvE Focus):
Axehook – Pull enemies together
Rock Smash – Stun and slow
Cyclone Slash – AoE burst + healing reduction
Tempest Strike – Sustained damage
Basic Attacks (with Rage) – Clean up survivors
This combo ensures enemies are grouped, controlled, and unable to escape while taking continuous damage.
Example Combo (PvP Burst):
Jump Cleave – Engage + armor reduction
Rage – Activate damage buff
Cyclone Slash – Apply anti-heal
Rock Smash – Lock down target
Basic Attacks – High-speed critical strikes
This sequence maximizes burst potential while preventing the enemy from recovering.
Playstyle Variations
Axes are flexible enough to support multiple playstyles depending on your skill choices.
1. The Berserker (Aggressive DPS)
Focus on Rage, Cyclone Slash, and Jump Cleave.
High burst damage
Constant pressure
Excels in small-scale fights
2. The Controller (Crowd Control Specialist)
Focus on Axehook, Rock Smash, and Primal Rush.
Dominates team fights
Controls enemy positioning
Enables team synergy
3. The Juggernaut (Sustained Fighter)
Focus on Tempest Strike and defensive timing.
High survivability
Strong AoE damage
Ideal for prolonged battles
PvE vs PvP Considerations
PvE
Axes excel in PvE due to their AoE capabilities and crowd control. Skills like Cleaving Strike and Tempest Strike make mob clearing efficient and satisfying.
Prioritize AoE damage
Use pulls to group enemies
Maintain Rage uptime for faster clears
PvP
In PvP, axes become tools of disruption and burst.
Use Jump Cleave for initiation
Apply anti-heal effects strategically
Control enemy movement with pulls and knockbacks
Timing and positioning are far more critical in PvP, making skill mastery essential.
Advanced Tips for Axe Users
Animation awareness matters: Many axe skills have noticeable wind-ups. Learn to anticipate and adapt.
Don’t waste Rage: Activate it when you can fully commit to attacking.
Control before damage: Pulling and stunning enemies often leads to more damage than rushing in blindly.
Positioning is everything: Axes require proximity—choose your engagements wisely.
Conclusion: The Axe as a Weapon of Dominance
Axes in Warborne Above Ashes Solarbite for sale offer one of the most satisfying combat experiences in the game. They reward aggressive play, smart ability chaining, and strong battlefield awareness. With a toolkit that combines raw damage, crowd control, and disruptive utility, axe users can dictate the flow of combat like few others.
Whether you’re cleaving through hordes of enemies or locking down key targets in PvP, mastering the axe arsenal turns you into more than just a damage dealer—you become a battlefield controller, a disruptor, and a relentless force that enemies cannot ignore.
For players willing to embrace the chaos and commit to close-range combat, axes are not just a weapon choice—they are a declaration of dominance.
