If you want a smooth start and a strong endgame character, the first week in Aion 2 should follow a clear progression path. The game gives you a lot of freedom—but if you rush into the wrong content too early, you'll fall behind in power. Here's a step-by-step plan that turns your early hours into long-term strength.
Step 1: Rush the Main Story to Max Level
Your number one priority is the main story quest (the yellow quest line). It carries you across the entire map and will naturally push you to level 45—often before the story even ends with Aion 2 Items for sale.
Focus only on the main story for the first 1–2 days.
You can hit max level in one long grind day, but two days is realistic and comfortable.
Avoid getting distracted by dungeons, crafting, or side activities early—they slow your leveling.
Hitting max level quickly is crucial because most of the real progression systems unlock at 45. That's when the game truly begins.
Step 2: Clear All Regional (Green) Quests for Deinian Power
Once you're level 45, press J and open the Regional tab. You'll see a list of green quests—these are not optional.
These quests reward:
Deinian Crystals
Kina (main currency)
Experience, titles, and other bonuses
Deinian Crystals are used on the Deinian Board, which works like a rune or talent system. Each board gives powerful bonuses such as:
HP, defense, crit
Cooldown reduction, combat speed
Damage boost and damage tolerance
PvE and PvP-specific stats
Some nodes give passives or skill upgrades, and these bonuses scale extremely well. In practice, most of your real power comes from this board, not just from gear.
Important:
The first four boards are mostly PvE-focused and can be completed from your home side content.
The last two boards (PvP-focused) require PvP activities and special crystals.
Do all regional quests. Players who skip these will be massively weaker in both PvE and PvP.
Step 3: Explore Sealed Dungeons and Strongholds
Next, open the map (M) and go to Exploration. Your goals:
Complete all Sealed Dungeons (dozens of mini-dungeons across the map)
Clear all Strongholds
Why this matters:
These give Deinian Crystals and Enhancement Stones
Enhancement Stones are required to upgrade (tap) your gear
Each sealed dungeon only takes a few minutes, but the rewards stack up fast
Strongholds are fewer and quicker, but just as important—especially for upgrading your belt later.
Do this before serious PvP. You'll walk into endgame much stronger than players who skipped this step.
Step 4: Collect Feathers and Feed the Monolith
While exploring, you'll find feathers all over the world (and later in PvP zones too). These are used at the Monolith in your main hub.
Feathers do three huge things:
Level up the Monolith
Grant skill points and passives
Give upgrade scrolls for your Amulet
Why the Amulet (and Belt) matter:
These two items are unique—you only ever get one of each
You cannot upgrade them like normal gear
The only way to upgrade them is:
Amulet → via Monolith (feathers)
Belt → via Strongholds and related systems
Upgrading these from green → blue → gold is one of the biggest power spikes in the entire game. The stat jump is massive, often doubling item level and giving huge percentage bonuses.
Tip:
Collect feathers everywhere:
Your homeland
Enemy zones via rifts
The Abyss (PvP zone)
PvP feathers also give PvP Deinian Crystals, which strengthen your PvP boards.
Step 5: Choose Your Path — PvE or PvP (Or Both)
At this point, you're strong enough to specialize:
PvE Path
Farm dungeons for higher item level gear
PvE weapons and armor often have slightly higher base stats
Great for boosting gear score and general performance
PvP Path
Use Abyss contracts/scrolls to earn Abyss Points
Spend points in the Battlefield Trade Shop
PvP gear includes PvP damage boost and damage tolerance (huge multipliers)
Even if base damage is slightly lower, the percentage PvP bonuses usually make PvP gear stronger in real fights
You can mix both paths. PvE raises your base stats; PvP gives you powerful multipliers for player combat.
Step 6: Do Your Daily Duties (Easy, Consistent Progress)
Open Journal → Duty and pick up your daily tasks:
You can do 5 per day
Rewards include:
Abyss Points
Kina
Chance at Enhancement Stones and other materials
These are quick, easy, and reliable. Over time, they:
Fund your PvP gear
Help you buy more Deinian Crystals
Keep your upgrades moving forward
The Big Picture: Where Your Power Really Comes From
A lot of new players think power = gear. In Aion 2, it's more like this:
~30% from gear and upgrades
~70% from Deinian Boards, passives, Monolith, and progression systems
That's why:
Main story → Regional quests → Sealed dungeons/Strongholds → Feathers/Monolith → PvE/PvP gearing
is the optimal order with Aion 2 Items.
Follow this route, and when you step into PvP or high-end PvE, you won't just survive—you'll dominate.
