Arc Raiders: Understanding the Shaker Instrument
Inviato: venerdì 13 febbraio 2026, 3:07
da RavenDrifter
What is the Shaker?
The Shaker is a rhythmic gadget in Arc Raiders that you can use to produce a repeating rhythm when you hold down the fire button. While it may seem like a fun, non-essential tool at first, it serves a specific purpose within the game. Using the Shaker can help attract the attention of ARC, as well as impress other players around you. It’s not just about the sound—it can be a useful addition to your arsenal in certain situations.
The Shaker’s function is relatively straightforward, but knowing when and how to use it effectively is key to getting the most out of it.
How Does the Shaker Work?
When you press and hold the fire button, your character will start playing one of two repeating rhythms. This rhythmic action is continuous as long as the button is held down. However, there’s a catch: while you’re using the Shaker, you won’t be able to use any other weapons, gadgets, or interact with containers and breaches unless you unequip the Shaker.
This makes it a strategic choice—do you want to spend time shaking to attract attention, or are you in the middle of a firefight and need to keep your weapons ready? It's important to weigh the risk and reward of using the Shaker. In situations where you need to be fully prepared for combat or rapid exploration, the Shaker might not be the best tool to carry.
The Shaker can be unequipped simply by switching to another gadget or weapon, which is useful when you need to quickly change your focus back to combat or exploration.
Where Can You Find the Shaker?
The Shaker can be found in certain locations within Arc Raiders. Specifically, you can locate it in Residential areas. These areas typically contain various gadgets and supplies that can be crucial for your survival and progression in the game. Once you have the Shaker, you can carry it around, but remember that its use in combat situations might not be the most effective.
Many players make the mistake of carrying the Shaker without fully understanding when to equip it. If you’re just running around gathering loot or fighting ARC, it may not be as valuable as other gadgets like breaching tools or combat-enhancing gadgets. However, if you're looking to add a bit of flair or create a distraction, the Shaker can be a lot of fun.
What Materials Are Needed to Repair the Shaker?
Like many gadgets in Arc Raiders, the Shaker can break over time and require repairs. It doesn’t cost much to repair it, but if you’re running low on resources, you may want to think carefully about when to fix it. To repair a Shaker, you’ll need 4 Plastic Parts. While this is relatively easy to gather, it’s always a good idea to keep track of your resources, especially when exploring new areas.
A fully repaired Shaker has a durability increase of +50, making it more resistant to wear and tear. Repairing it frequently can ensure that you’re always ready to entertain or distract when necessary, but it's essential not to waste resources if you’re not actively using the Shaker.
Can the Shaker Be Recycled or Salvaged?
Yes, you can recycle or salvage the Shaker if you no longer need it. Recycling a Shaker gives you 10 Plastic Parts, while salvaging it returns 4 Plastic Parts. This is a useful option if you’re running low on space or resources and need to clear out some gadgets. It’s worth noting that salvaging may not yield as much material as recycling, but it can be a quick way to free up inventory slots when you’re in a pinch.
If you’re ever wondering whether you should keep or discard your Shaker, consider whether you need to repair any gadgets and whether the Shaker’s entertainment value is still relevant to your playstyle. If you're more focused on combat and survival, you might prefer salvaging the Shaker for the plastic parts.
Should You Buy the Bobcat Blueprint?
The Bobcat Blueprint is another gadget you can acquire in Arc Raiders, and some players may be wondering if it's worth the investment to buy it. While it's not directly related to the Shaker, it’s a good example of how you need to balance your resources in Arc Raiders. The Bobcat Blueprint offers a different set of benefits, such as providing additional mobility or combat effectiveness. If you’re looking to broaden your inventory with more practical gadgets, you might want to buy Bobcat Blueprint instead of focusing on the Shaker for now.
However, for those players who enjoy using gadgets creatively or who want a unique way to interact with the game, the Shaker could still be a fun tool to have. If you’re interested in exploring different gameplay mechanics, it might be worth holding onto the Shaker, even while also working towards other blueprints like the Bobcat.
When Should You Use the Shaker?
In practice, the Shaker is most useful when you’re in a safe zone or have the luxury of not needing to fight for your life. If you’re in a Residential area or exploring somewhere relatively calm, pulling out the Shaker and holding down the fire button can give you a bit of fun and might even attract attention from ARC. It's also a great way to show off to other Raiders when you're not worried about combat.
However, in high-stress combat situations, using the Shaker isn’t always practical. You won’t be able to engage with enemies effectively while you’re shaking. So, save it for moments when you can afford to take a break from combat or are just messing around with friends.
The Shaker in Arc Raiders is a unique gadget that offers both fun and strategy. It may not be the most powerful tool in terms of combat, but its ability to create rhythm and attract attention makes it a valuable asset in certain situations. Whether you're looking to entertain, impress, or simply add a bit of flair to your gameplay, understanding how and when to use the Shaker can help you make the most of it. Keep in mind that while it’s an uncommon gadget, its utility is situational. Decide if you want to carry it based on your goals for the mission at hand.
Vulcano Blueprint | All Platform
