Light Shield vs Medium Shield in Arc Raiders: A Player's Guide
  • RavenDrifter
    Auto posseduta: Volkswagen ID.3
    nome: RavenDrifter
    da RavenDrifter » giovedì 5 febbraio 2026, 7:19
    What’s the Difference Between Light and Medium Shields?
    1. Damage Mitigation
    The most significant difference between the Light Shield and the Medium Shield is the amount of damage they can absorb.
    Light Shield: It offers a 40% damage mitigation. This means that it blocks 40% of the damage you would otherwise take from enemy attacks.
    Medium Shield: The Medium Shield, on the other hand, provides a stronger 60% damage mitigation, making it a more reliable choice when you anticipate taking significant damage.
    In practice, this means that the Light Shield will offer basic protection, which can be helpful in early engagements or for players who prioritize mobility. However, the Medium Shield provides a bit more of a buffer against higher damage, which can make a huge difference when facing tougher enemies or during intense firefights.
    2. Shield Charge and Durability
    Both shields require a certain amount of shield charge to activate, and they also have their own durability to consider.
    Light Shield: It requires 40 Shield Charge and has a lower durability compared to the Medium Shield. This means you'll need to recharge your Light Shield more often, especially if you're taking a lot of damage.
    Medium Shield: It has a higher durability and requires more Shield Charge to use, typically around 60. While it lasts longer before needing a recharge, you'll need to plan your Shield Charge management more carefully to avoid running out when you need it most.
    Both shields can be repaired and recycled, but the Medium Shield is more resilient overall. For extended encounters, this extra durability can save your life, especially in longer, more drawn-out fights.
    How Does Mobility Factor Into the Shield Choice?
    1. Movement Penalty
    One of the main advantages of the Light Shield is its lack of a movement penalty. It allows you to sprint and move freely while still providing protection. This makes it ideal for hit-and-run tactics or for players who prefer an agile playstyle.
    Light Shield: No movement penalty. You can run, dodge, and strafe without sacrificing your defensive capabilities.
    Medium Shield: The Medium Shield, while more durable, typically comes with a noticeable movement penalty. Your speed will be reduced, and your agility in combat will suffer a bit. This is a trade-off for the increased protection.
    If you value speed and maneuverability over sheer damage absorption, the Light Shield is a solid choice. However, if you're willing to sacrifice some movement for a bit more durability, the Medium Shield might be the better option.
    When Should You Use the Light Shield?
    1. Mobility-Centric Playstyle
    If you’re a player who relies on moving quickly around the map, dodging enemy fire, and repositioning frequently, the Light Shield is a great choice. It allows you to maintain your pace while still protecting you from some incoming damage. In situations where staying on the move is key — such as when completing objectives or evading enemies — the Light Shield gives you the flexibility you need without slowing you down.
    2. Early-Game and Low-Risk Engagements
    The Light Shield is also a fantastic option for players who are early in the game or engaged in lower-risk combat. When you’re still building your gear and aren’t dealing with massive damage from high-level enemies, the Light Shield can be sufficient for many situations. It's also a good option for PvP if you're confident in your ability to outmaneuver your opponent rather than tank damage head-on.
    When Should You Use the Medium Shield?
    1. Tankier, More Durable Playstyle
    For players who prefer to take on a tankier role, the Medium Shield is a far better option. With its higher damage mitigation and better durability, the Medium Shield allows you to soak up more damage, giving you the ability to stand your ground during intense firefights.
    2. Dealing with High-Damage Enemies
    When facing tougher enemies or bosses in Arc Raiders, you’re going to need all the protection you can get. The 60% damage mitigation of the Medium Shield can be the difference between surviving a direct hit and getting wiped out. This makes it an excellent choice when engaging high-damage enemies, especially those with area-of-effect (AoE) attacks or rapid-fire weapons.
    3. Objective and Team Play
    If you’re playing in a team and you’re tasked with holding positions or protecting objectives, the Medium Shield excels. It gives you the resilience to stay in position longer, whether you’re defending an area or providing support for your team. You won’t have to worry about constantly repositioning as much, allowing you to focus more on your role in the team.
    Shield Strategy: Which Is Better?
    The decision to use the Light or Medium Shield comes down to your playstyle and the situation you’re facing.
    If you prefer high mobility and are dealing with lower risks, the Light Shield is your best bet. It's lightweight and doesn't slow you down, making it perfect for quick engagements and dodging enemy attacks.
    If you’re facing tough enemies or are playing a tanky role, the Medium Shield is the better choice. Its higher damage mitigation and durability provide more reliable protection when you're under heavy fire.
    Can You Switch Between the Two Shields?
    Yes, depending on your loadout and available resources, you can switch between the two shields based on your needs. This is especially useful when you're preparing for a boss fight or a more tactical engagement where you know you'll be taking a lot of damage.
    In the end, both the Light Shield and Medium Shield have their strengths, and the best choice for you depends on your preferred playstyle and the situation you’re in. The Light Shield offers unmatched mobility and is perfect for players who want to stay agile and keep moving. On the other hand, the Medium Shield offers more durability and better damage mitigation, making it a solid choice for tankier roles or tougher enemies.
    If you’re still gearing up or looking for better equipment, don’t forget you can buy arc raiders Equalizer blueprint for more advanced gear options down the line. Keep experimenting with both shields to find the right balance for your gameplay.
    Arc Raiders Vulcano Blueprint Location, Use, Craft Recipe
