Arc Raiders: Crude Explosives Location Guide
Inviato: giovedì 22 gennaio 2026, 5:59
da RavenDrifter
What are Crude Explosives?
Crude Explosives are an uncommon item in Arc Raiders. They serve a couple of key purposes: they can be thrown to create a small explosion, or they can be recycled into crafting materials. The main role of Crude Explosives, however, is as a component in crafting more advanced explosives, like grenades and other explosive devices. They're particularly useful if you're planning to create the following:
Seeker Grenade
Pulse Mine
Shrapnel Grenade
Snap Blast Grenade
Trigger 'Nade
As you progress, you'll need to gather them to upgrade your arsenal and stay ahead of enemies.
Where Can You Find Crude Explosives?
Crude Explosives can be found in several locations around the map, most commonly in Industrial and Security areas. Here's where to look:
1. Industrial Loot Containers
These are one of the best sources for Crude Explosives. You will typically find them in:
Metal Crates – These are scattered throughout the map in locations like:
Dam Battlegrounds > Research and Administration > West Tunnels
Spaceport > Shipping Warehouse
Dam Battlegrounds > Power Generation Complex
Metal Crates contain a variety of useful items, including Crude Explosives, Rubber Parts, and Explosive Compounds, which are all valuable for crafting and survival.
2. Security Areas
Pop ARC and Fireball ARC are high-risk, high-reward locations where you can also find Crude Explosives in loot containers.
These areas are usually more protected, meaning you’ll have to deal with stronger enemies or environmental hazards. But they’re worth checking out if you're in need of Crude Explosives.
By regularly scavenging in these areas, you should be able to gather a steady supply of Crude Explosives.
How to Craft Crude Explosives
If you’re unable to find enough Crude Explosives through scavenging, you can craft them. The crafting process is straightforward but does require some resources:
Crafting Recipe:
6x Chemicals
Refiner 1 required
This is a relatively simple crafting process that can be done in your Refiner station (once it's upgraded to level 1). While gathering Chemicals may take time, it’s a good backup option if you're running low on Crude Explosives.
How Are Crude Explosives Used in Crafting?
Crude Explosives are a key ingredient in several explosive recipes. Once you have them, you can craft more advanced explosives. Here's a quick rundown of what you can craft using Crude Explosives:
1. Explosive Compound
Requires: 2x Crude Explosives + 2x Oil
Crafting Station: Refiner 2
Explosive Compound is a more refined item that’s necessary for crafting various weapons and devices.
2. Launcher Ammo
Requires: 1x ARC Motion Core + 2x Crude Explosives
Crafting Station: Workbench 1
Launcher Ammo is critical for powerful launchers, adding explosive capabilities to your arsenal.
3. Pulse Mine
Requires: 1x Crude Explosives + 1x Wires
Crafting Station: Explosives Station 1
Pulse Mines are highly effective in traps or controlling enemy movements.
4. Seeker Grenade
Requires: 1x Crude Explosives + 2x ARC Alloy
Seeker Grenades target enemies automatically, making them great for offensive strategies.
5. Shrapnel Grenade
Requires: 1x Crude Explosives + 2x Steel Spring
Crafting Station: Explosives Station 2
Shrapnel Grenades deal explosive damage and release dangerous shrapnel, perfect for area denial.
6. Snap Blast Grenade
Requires: 2x Crude Explosives + 1x Magnet
A versatile grenade with a wide blast radius, useful for crowd control.
7. Trigger 'Nade
Requires: 2x Crude Explosives + 1x Processor
Trigger 'Nades are a fantastic option for setting traps and ambushes.
How to Recycle Crude Explosives
If you find yourself with an excess of Crude Explosives or don’t need them for crafting, you can recycle them to recover valuable materials. Recycling Crude Explosives yields Chemicals, which are useful for crafting other items.
Recycling Process:
Recycle Crude Explosives to get 3x Chemicals
Recycling Station required
Alternatively, if you don’t want to recycle them, Crude Explosives can also be salvaged for 2x Chemicals.
Are Crude Explosives Worth Crafting or Buying?
You might be wondering whether it’s better to spend time scavenging for Crude Explosives or buy them outright. If you're looking to buy Arc Raiders blueprints Xbox from U4N, it can sometimes be faster to purchase Crude Explosives or the necessary blueprints, depending on your in-game situation. However, crafting and scavenging are still the most reliable ways to gather them, especially if you're trying to conserve in-game currency.
Tips for Efficient Gathering
Focus on Industrial Areas: These zones are your best bet for finding Crude Explosives. Focus on Metal Crates and loot containers in locations like Dam Battlegrounds and Spaceport.
Upgrade Your Refining Stations: Crafting Crude Explosives can save you time if you gather Chemicals regularly.
Recycling is Key: If you accumulate too many Crude Explosives, don’t forget you can recycle them into useful crafting materials.
Ultimately, Crude Explosives are a flexible resource that can help you craft powerful items or deal with enemies effectively. Keep an eye on your loot containers, craft when necessary, and you’ll have all the explosives you need to survive the chaos of Arc Raiders.
Resource Center: Level Up Faster with ARC Raiders Boosting at U4N
