If you’re playing Aion 2 as a Sorcerer, you’ve probably heard about the Splendent Horned Dragon Lord Tome. It’s a Heroic Spellbook with high stats, but many players wonder how it works in practice and whether it’s worth pursuing. In this guide, I’ll explain what this item does, how to get it, and tips on handling it in the game, based on how most players actually use it.
What is the Splendent Horned Dragon Lord Tome?
The Splendent Horned Dragon Lord Tome is a Heroic Spellbook exclusive to Sorcerers. It has an item level of 114, making it one of the stronger options for mid-to-late level PvE and PvP. Here’s a quick look at its stats:
Attack Min: 518
Attack Max: 575
Accuracy: 100
Critical Hit: 100
Block: 0
PvE Damage Boost: 5%
Manastone Slots: 5
In general, players value this tome for its balance between raw spell damage and PvE utility. The five manastone slots are particularly useful because you can customize it to increase your attack power, critical rate, or even defensive stats depending on your playstyle.
Who Can Use This Tome?
This spellbook is only usable by Sorcerers. Most other classes won’t benefit at all, as it’s specifically designed for their spellcasting mechanics. Sorcerers usually rely on high burst damage and precise spell timing, so the stats of this tome—particularly the accuracy and critical hit—fit well into their build.
How Do You Get the Splendent Horned Dragon Lord Tome?
Currently, the main method to obtain this tome is through crafting a draconic combo. There aren’t many other confirmed sources, and details on the exact components or crafting process are still limited. From player experience:
Crafting is the most consistent route if you have the resources and the necessary crafting level.
Some players attempt to farm rare drops or check the auction system, but this can be expensive and unreliable.
The crafting process usually requires gathering multiple rare materials, often from draconic mobs or high-level quests. In general, if you’re planning to craft it, be prepared for some resource investment and a bit of time hunting the necessary components.
How Valuable is This Tome?
The Splendent Horned Dragon Lord Tome is considered a high-value item. On some servers, it can sell for over 10 million gold. Most players who acquire one either keep it for their own Sorcerer or sell it to other players. If you decide to sell it, it’s important to do so safely—experienced players often sell Aion 2 kinah safely on U4N to avoid scams and ensure a smooth transaction.
How Do Players Use It in Practice?
In general, the Splendent Horned Dragon Lord Tome is used primarily for PvE content. The 5% PvE damage boost makes it effective in dungeons, raids, and other group content. Here’s how most players approach it:
PvE Boost: Sorcerers using this tome usually focus on burst damage to bosses or elite mobs. The combination of high min/max attack and critical hit makes many skills hit harder than with standard weapons.
Manastone Customization: Players often socket manastones to maximize critical hit or accuracy, depending on their gear set and stat priorities. Some also invest in defensive manastones for tougher raid fights.
PvP Considerations: While the tome can be used in PvP, most players find that the PvE damage boost doesn’t directly help in player combat. It’s still viable if you want raw spell damage, but specialized PvP gear is often better.
Crafting vs Buying
If you have the crafting skills and access to the necessary materials, crafting is usually the best route. It can save gold and give you control over which stats to enhance.
However, some players prefer to buy the tome from other players, especially if they don’t want to spend the time gathering materials. In this case, make sure to handle the transaction carefully. As mentioned earlier, a safe marketplace like U4N is often used to sell or purchase high-value items.
Key Takeaways for Sorcerers
The Splendent Horned Dragon Lord Tome is exclusive to Sorcerers and offers strong PvE damage.
Item level 114 and five manastone slots make it flexible for customization.
Crafting through a draconic combo is the main way to obtain it, though it may require significant resources.
If selling, experienced players recommend using safe platforms to sell Aion 2 kinah safely on U4N.
While usable in PvP, most players prioritize it for raids and dungeons.
In practice, this tome is a valuable addition for any Sorcerer who wants to maximize their spell damage in group content. It’s not a casual item—you need some investment of time or gold to acquire it—but the payoff in PvE performance is generally considered worth it.
For Sorcerers in Aion 2, the Splendent Horned Dragon Lord Tome is one of the stronger Heroic Spellbooks available. It provides a solid mix of damage, critical hit, and customization potential. While the crafting details aren’t fully disclosed yet, players who invest in gathering the necessary materials usually see a significant benefit in PvE content. Whether you craft it or buy it, handling high-value transactions safely is key, and using secure platforms can prevent headaches.
