If you’re playing Arc Raiders, you’ve probably come across references to the Angled Grip II Blueprint. Understanding how it works, where to find it, and how to craft the item can make your gameplay more efficient. Here’s a detailed guide based on how most players handle this blueprint in practice.
What is the Angled Grip II Blueprint?
In general, a blueprint in Arc Raiders is an item that allows you to craft a specific piece of equipment. The Angled Grip II Blueprint is no exception. Once you have it, you can craft an Angled Grip II, which is an attachment that helps improve weapon handling.
Most players treat the blueprint as a key step in upgrading their guns. Without it, you cannot create the grip, even if you have all the crafting materials. The blueprint itself has a value of 5000 in-game, but its primary use is practical: unlocking crafting options.
How Do You Get the Angled Grip II Blueprint?
The usual way to get this blueprint is through looting. In general, players report that the blueprint appears in topside areas, which are areas above ground in the game. While the spawn can feel random, most players find that regularly exploring these areas during missions or open-world runs increases your chances of finding it.
It’s worth noting that the blueprint is not tied to a specific enemy or guaranteed drop from a particular location. Many players suggest checking multiple topside zones, as repeated visits often yield more blueprints.
Some players also look for ways to acquire it indirectly, such as trading with others in the community or using online sources. However, if you are considering shortcuts, a common search is buy arc raiders blueprints online. This phrase is often used by players looking to skip the grind, though it’s important to approach this with caution and follow game rules.
What Do You Need to Craft an Angled Grip II?
Once you have the blueprint, crafting requires both skills and materials. Usually, players focus on having the right gunsmithing level first:
Gunsmith 2: This is the minimum skill level needed. Most players level up their gunsmithing by crafting simpler attachments first.
Materials: To craft the Angled Grip II, you need:
2x Mechanical Components
3x Duct Tape
In general, these materials are common enough that players gather them while doing missions or scavenging topside areas. Mechanical Components are usually found in broken machinery or crates, and Duct Tape can be looted from supply boxes or enemy caches.
How Do Most Players Use the Angled Grip II?
The Angled Grip II is valued for improving stability and handling. In practice, most players attach it to rifles or other mid-range weapons. Its effect is subtle but noticeable, especially for players who rely on precision shooting or prefer semi-automatic fire.
Usually, players equip it on a primary weapon and combine it with other handling upgrades. It’s not a game-changer on its own, but it contributes to smoother aiming and recoil control, which is important in high-level play or when taking on multiple enemies.
Tips for Managing Blueprints and Crafting
Inventory Management: Most players recommend keeping blueprints in a dedicated section of your inventory. This prevents accidentally selling or discarding them.
Skill Progression: Focus on leveling up gunsmithing gradually. Without Gunsmith 2, you can’t craft the grip, even if you have materials and the blueprint.
Resource Planning: Collect materials consistently rather than waiting until you have the blueprint. This way, you can craft immediately when you find it.
Community Knowledge: Checking guides or wikis can help identify likely spawn areas for blueprints. The blueprint arc raiders wiki guide is often referenced by players who want detailed drop locations.
Common Player Questions
Q: Can I find the Angled Grip II Blueprint more than once?
Yes. In general, players can loot multiple blueprints, and each one allows crafting another grip. Some players collect extras in case they want to craft more than one or sell/trade in-game.
Q: Do I need a specific weapon to use it?
No. The grip is compatible with most rifles or weapons that support attachments. Most players prefer it on mid-to-long-range firearms for recoil control.
Q: How long does it take to craft?
Crafting is usually instant once you have the blueprint, the required skill level, and materials. The limiting factor is gathering materials and leveling Gunsmith 2.
Q: Are there alternatives to the Angled Grip II?
Yes, the game includes several grips and attachments. However, most players choose Angled Grip II for its balance between control and ease of acquisition.
The Angled Grip II Blueprint is a straightforward but essential item in Arc Raiders. It allows you to craft a grip that improves weapon handling, especially for rifles. In practice, finding it requires exploring topside areas, and crafting needs Gunsmith 2 along with a few basic materials. Most players treat it as a stepping stone in weapon optimization rather than a must-have for basic gameplay.
Being strategic about blueprint management, material gathering, and skill leveling can make the process smoother. For those who prefer shortcuts, searches like buy arc raiders blueprints online are common, though always proceed carefully with external transactions.
By understanding where it drops, how to craft it, and how most players use it, you can integrate the Angled Grip II into your loadout efficiently and improve your combat performance without unnecessary trial and error.
