How to Use ARC Flex Rubber in Arc Raiders: A Recycling Guide
  • BloodRanger
    Auto posseduta: CHINA
    da BloodRanger » lunedì 5 gennaio 2026, 8:02
    Arc Raiders is a game full of crafting, scavenging, and surviving. As you progress, you’ll encounter various materials, each with its own use in helping you craft or salvage essential items. One of these materials is ARC Flex Rubber, a versatile resource that plays a role in crafting and recycling. In this guide, we’ll dive into everything you need to know about ARC Flex Rubber, including how to obtain it, its use in recycling, and its potential benefits in the game.
    1. What is ARC Flex Rubber?
    ARC Flex Rubber is a rare item in Arc Raiders. It is a recyclable material, meaning it can be repurposed for other uses, particularly in crafting rubber parts. Most players will encounter it while exploring ARC or engaging in specific activities or battles against ARC enemies.
    In general, ARC Flex Rubber doesn’t have a direct crafting recipe or significant standalone value. Instead, its real worth comes when it is recycled into rubber parts—an important material used in other crafting recipes.
    2. How to Obtain ARC Flex Rubber?
    In Arc Raiders, ARC Flex Rubber is typically obtained from two main sources:
    ARC Enemies: As you battle against enemies in the ARC environment, you’ll often find this material as a drop. While it's not guaranteed, defeating ARC enemies is one of the most reliable ways to get ARC Flex Rubber.
    Activities: Completing various in-game activities, especially those tied to ARC, might reward you with ARC Flex Rubber. While it's not a common drop in every activity, you’ll still come across it during your explorations and encounters.
    3. Can ARC Flex Rubber Be Crafted?
    Unlike many other materials in Arc Raiders, ARC Flex Rubber cannot be crafted. This makes it a unique item in that it’s solely obtained through activities or enemy drops. This means that, for most players, it will be one of those items that you need to collect over time while you're out exploring and fighting.
    4. Recycling and Salvaging ARC Flex Rubber
    One of the primary uses for ARC Flex Rubber in Arc Raiders is in recycling and salvaging. Most players will find that recycling this item into rubber parts is one of the best ways to put it to use.
    Recycling at the Raider Den
    In the Raider Den, you can recycle ARC Flex Rubber into 16x Rubber Parts. This is a great way to get a large amount of rubber parts in exchange for just one unit of ARC Flex Rubber. This makes it valuable, especially for players who are focusing on gathering materials for crafting or upgrading equipment.
    Salvaging Topside
    If you’re salvaging items on the Topside, you’ll be able to turn ARC Flex Rubber into 9x Rubber Parts. While this is fewer than what you get from recycling, it’s still a useful way to gain rubber parts if you're already salvaging other materials from the environment.
    In general, recycling and salvaging are two of the main methods players use to convert ARC Flex Rubber into a more useful form. Since rubber parts are frequently needed for crafting and other game mechanics, having a good stockpile of ARC Flex Rubber can make your gameplay experience smoother and more efficient.
    5. Where Can You Use Rubber Parts?
    Rubber parts, which you get from ARC Flex Rubber, are used in a variety of crafting recipes and upgrades in Arc Raiders. Players will often need rubber parts for crafting essential equipment, such as:
    Tools: Certain tools require rubber parts for durability and functionality.
    Upgrades: Many base upgrades or vehicle upgrades will need rubber parts as part of the crafting process.
    Weapons & Armor: Some weapons and armor might require rubber parts for enhanced protection or functionality.
    Since rubber parts are essential for many game activities, collecting ARC Flex Rubber and recycling it is a smart choice if you're looking to stay well-equipped in the game.
    6. Practical Tips for Managing ARC Flex Rubber
    Don’t Hoard Unnecessary Materials: It’s easy to end up hoarding lots of materials in Arc Raiders. While ARC Flex Rubber might seem useful, remember that its primary function is in recycling. If you’re not in immediate need of rubber parts, it’s okay to keep a small stock of ARC Flex Rubber but don’t over-accumulate it.
    Focus on Recycling: Since recycling ARC Flex Rubber gives you 16x Rubber Parts at the Raider Den, make sure you use this opportunity to gather rubber parts. You can save time and space by focusing on this method, especially if you know you’ll need a lot of rubber for crafting or upgrading.
    Check Topside Salvage: Don’t forget about salvaging ARC Flex Rubber while you’re on the Topside. It might be worth your while if you’re already in the process of salvaging other items. Even though it gives fewer parts than recycling, it’s still a useful way to gain materials.
    While ARC Flex Rubber might seem like a simple item at first glance, its value comes from its recycling potential. Most players use it to get rubber parts, which are essential for crafting and upgrading equipment in Arc Raiders. By knowing where to find it, how to use it, and when to recycle or salvage it, you can make the most of this resource and enhance your gameplay experience.
    ARC Raiders blueprint sellers can use U4N with confidence: https://www.u4n.com/arc-raiders/items
