If you’ve been playing Arc Raiders, you probably have questions about how to handle resources, gear, and crafting efficiently. In this guide, I’ll break down common questions and explain how things work in practice, based on what most players experience.
How Does Crafting Work in Arc Raiders?
Crafting is a core part of Arc Raiders. Most players will spend a lot of time gathering components to upgrade their equipment. In general, you need two types of materials: Mechanical Components and Simple Gun Parts. These items can be collected from missions, enemy drops, or certain in-game events.
For example, if you want to craft an Anvil (Gunsmith I), you’ll need 5x Mechanical Components and 6x Simple Gun Parts, along with $5000 in in-game currency. In practice, most players focus on farming these materials from missions they can complete efficiently, rather than chasing random drops.
Once you have the required materials, you go to your crafting station. Crafting times are usually short, but keep in mind that upgrading to higher-tier gear often requires multiple crafting steps. Most players recommend saving up materials for higher-tier gear rather than crafting everything as soon as you can.
Which Items Should I Prioritize Crafting?
In general, prioritizing depends on your play style and the missions you run most often.
Weapons: Usually the first priority because higher firepower makes missions faster and safer.
Defensive Gear: Armor or shields are next. Most players find that survivability is more important than raw damage in higher-level missions.
Utility Items: Items like drones or traps are situational. Only craft these if you have extra materials or a specific mission requirement.
The Anvil (Gunsmith I) is a common early-game crafting choice. While it doesn’t change gameplay dramatically on its own, it’s usually part of the gear progression chain. Most players craft it as soon as they can because it lays the foundation for better weapons later.
How Do I Get the Materials Efficiently?
Most players quickly realize that farming materials is a mix of strategy and routine. Here’s what usually works:
Mechanical Components: These are often dropped by mid-tier enemies and mission-specific crates. Running the same missions repeatedly is common.
Simple Gun Parts: These usually come from weapon-specific enemies or dismantling old weapons. In general, dismantling gear you don’t use is faster than grinding missions for these parts.
Time management is important. Most players don’t try to farm every material in a single session. Instead, they focus on missions that give multiple materials at once. This approach reduces downtime and makes resource gathering feel more purposeful.
What About Money?
$5000 for an item like the Anvil might sound like a lot early in the game. In practice, most players have no trouble earning it if they focus on efficient missions and side objectives. Looting and selling unwanted items is usually faster than grinding missions endlessly.
A tip many players use: plan your crafting around your current cash reserves. Avoid hoarding materials for future gear unless you have plenty of money. In general, balancing materials and currency ensures you can craft without interruptions.
Can I Speed Up Progress With Blueprints?
Blueprints are a big part of crafting. Most players collect them during missions, but some look for alternative ways to access them faster. For instance, you might see offers to buy blueprints online. If you are considering options like that, you might search for “buy arc raiders blueprints cheap,” but keep in mind that the safest way to get blueprints is through legitimate in-game sources. Most players rely on the game’s crafting system because it ensures you get the materials in a structured way.
How Do Most Players Approach Gear Progression?
Gear progression in Arc Raiders usually follows this pattern:
Craft Early Weapons: Items like the Anvil (Gunsmith I) are early milestones. Most players craft these first to boost combat effectiveness.
Upgrade Survivability: After getting basic weapons, focus on armor, shields, or health-boosting gear.
Refine Loadout: Once you have a basic setup, players often tweak their loadout to match their preferred missions. Utility items and rare weapons come last because they are usually mission-specific.
In practice, this approach works well because it balances combat power and resource management. Trying to craft everything at once usually leads to wasted materials and frustration.
Tips From Experienced Players
Don’t Hoard Materials: Craft what you need when you need it. Materials and cash are easier to earn than you might think, so waiting too long is usually unnecessary.
Repeat Efficient Missions: Some missions drop more materials than others. Focus on those for faster crafting.
Track Gear Progression: Keep a mental or written note of what components you need for future upgrades. Most players find this reduces unnecessary farming.
Combine Resource Sources: Dismantling old gear, completing missions, and selling unused items together is usually the fastest way to gather materials.
Crafting in Arc Raiders is straightforward once you understand the resource flow and progression. Most players focus on balancing weapons, survivability, and utility items while farming materials efficiently. Items like the Anvil (Gunsmith I) are usually crafted early to support future gear upgrades. Following a methodical approach and planning for cash and materials ensures smoother gameplay and less wasted effort.
