The recent update in our favorite plant defense game has introduced some incredible opportunities for players to push their damage output to unprecedented levels. With the new max plant level now at 10, there’s a real incentive to optimize your garden for maximum DPS, and one plant in particular, the Neon Tomatrio, has proven to be the undisputed damage king. I recently took my 10 million DPS Neon Tomatrio and managed to push it all the way to 109 million damage per second, using a combination of clever leveling strategies, card merges, and potion buffs. Here’s a detailed breakdown of how I achieved it and some tips you can apply.
Leveling Your Neon Tomatrio
The first step is straightforward: get your Neon Tomatrio to the new level cap of 10. Start by placing it in a position where it can target as many enemies as possible—central tiles are ideal. I used a combination of experience bottles and stars to rapidly increase the plant’s level. By carefully timing the use of your exp resources, you can get your Neon Tomatrio from level 7, where it starts at around 6.9 million DPS, all the way up to level 10, unlocking a massive boost in base damage.
Optimizing Damage Cards
Once your plant is max level, the next step is to stack damage cards. Halloween card packs are particularly valuable in this update, offering new tier 3 cards that significantly increase DPS. Key cards include:
Tile Focus: Standing on a tile with a plant increases its damage.
Center of Attention: The plant in the center gains extra damage and attack speed.
Trick or Treat: Killing a set number of brain rots grants temporary DPS boosts.
Merging cards to tier 3 is crucial. It multiplies their effects and can dramatically boost your Neon Tomatrio’s damage output. For example, combining multiple copies of the “Center of Attention” card resulted in a 40% increased attack speed and 15% damage boost. Don’t forget to adjust your card loadout to ensure the most effective cards are active at all times. If you’re struggling to find specific cards, consider strategies to buy sab brainrots or buy steal a brainrot items to accelerate collection.
Potions and Additional Buffs
Damage potions are another significant multiplier. Each potion increases base DPS by 50%, and when combined with certain card bonuses, the effective boost can exceed 60%. For maximum impact, activate potions once your plant is at level 10 and all key cards are equipped. This ensures that your Neon Tomatrio benefits fully from all buffs simultaneously.
Strategic Placement
Finally, positioning is critical. Make sure your Neon Tomatrio occupies the central tile and remove any surrounding plants that could limit the effects of area-based damage cards. By ensuring it is the “center of attention” and supported by the right cards and potions, I was able to push DPS from an already impressive 11 million at level 9 to over 54 million on-screen, effectively doubling to 109 million actual damage per second thanks to its firing rate.
Summary
By following these steps—leveling your Neon Tomatrio to max, carefully merging and equipping tier 3 damage cards, using damage potions, and optimizing placement—you can achieve mind-blowing DPS numbers that make even the toughest enemies crumble. The key takeaway is that maximizing plant damage now requires a thoughtful combination of leveling, card management, and strategic buffs. Don’t hesitate to buy sab brainrots or buy steal a brainrot items to speed up your progression. With these strategies, there’s no limit to how powerful your plants can become in the new update.
