Shielded enemies in Elden Ring can be a serious headache. They turtle behind their shields, block every swing, and punish careless aggression. Whether you're a melee bruiser or a dexterous mage, it's important to know how to deal with these defense-heavy foes efficiently. Here are 8 reliable tricks experienced Tarnished use to overcome shielded enemies—and come out on top.
1. Use Guard Breaks to Shatter Their Defense
Most shielded enemies can be staggered if you apply enough pressure. Two-handed heavy attacks and charged R2 strikes are your best bet. If you manage to deplete their stamina, you'll open them up for a critical hit. Greatswords and colossal weapons work well here.
2. Try Jump Attacks
Jumping attacks deal significant posture damage and can often stagger an enemy holding up a shield. If you're using a heavy weapon or dual-wielding, a well-timed jump attack can break their guard faster than standard swings.
3. Exploit Fire and Lightning Weaknesses
Many shielded enemies are vulnerable to elemental damage, particularly fire and lightning. Fire Grease, Lightning Pots, or even a spell like Catch Flame can bypass the shield’s block rate. These quick elemental bursts force your enemies to reconsider hiding behind their guard.
4. Use Guard Counters Effectively
If you're the one blocking, don't forget to retaliate with a Guard Counter (R2 immediately after blocking an attack). It can break the posture of shielded humanoid enemies, especially if you follow up aggressively before they reset.
5. Circle Around for Backstabs
Some enemies rely heavily on frontal defense, making them vulnerable from behind. Strafing around and baiting an attack can open them up for a clean backstab. This works particularly well against slower soldiers and knights.
6. Use Ashes of War That Break Guards
Ashes of War like Flaming Strike, Storm Blade, or Hoarfrost Stomp can either bypass or overwhelm shields. Equipping the right skill can turn a frustrating fight into a quick victory. These skills work well on most weapon types and are essential when fighting tanky foes.
7. Utilize Magic or Ranged Attacks
Sometimes brute force isn't the answer. Spells like Magic Glintblade or Night Shard ignore shielded enemies’ defenses and deal damage directly. Even simple arrows, when fired from a safe distance, can chip away and keep pressure on. Just don’t let them close the gap.
8. Summon Distractions
Summons and Spirit Ashes can pull aggro away from you, giving you an opening to flank the enemy or deal damage while they're distracted. Lone Wolf Ashes or Skeletal Militiamen work well here, creating enough chaos to bypass stubborn shields.
Whether you're exploring the Lands Between solo or preparing for tougher boss fights, understanding how to break through defenses is essential. These tricks aren’t just for PvE—many of them translate well into PvP too. If you’re optimizing your build, managing your rune stash, or upgrading weapons to deal with tougher foes, make sure you’re properly stocked.
Sometimes, it helps to get a head start—many players choose to buy Elden Ring runes online or look for the best place to buy Elden Ring items to boost their arsenal before diving into the more punishing parts of the game. With the right tools and strategies, even the most heavily armored foes become manageable.
