With the release of the highly anticipated Elden Ring DLC, players are diving back into the Lands Between, eager to explore fresh content and enhance their character builds. One weapon that shines in this expansion is the Bleeding Claymore, a versatile option that combines substantial physical damage with impressive bleed potential.
To effectively wield the Bleeding Claymore, players need 14 Strength and 18 Agility. This makes it an excellent choice for both Strength and Agility builds, appealing to those who enjoy hybrid playstyles. When infused with Quality Affinity, the Claymore achieves a B rating in both attributes, ensuring it scales effectively with either.
Infusing the Claymore with Quality Affinity maximizes its attack rating and enhances its scaling effects, allowing for notable damage output while retaining combat versatility. Players can customize their builds to align with their preferred playstyle.
A standout feature of the Bleeding Claymore is its ability to inflict bleed damage. This status effect gradually reduces an enemy's health, making it particularly effective against tougher foes. The Claymore’s Ash of War lets players execute powerful attacks that can quickly stack bleed damage.
To further amplify the Bleeding Claymore's effectiveness, consider pairing it with the Finger Seal as a secondary weapon. This combination allows players to cast critical hit buffs and offensive spells, enriching their combat strategy. The Finger Seal can be purchased from the Twin Maiden Husks for 800 Elden Ring Runes, making it an accessible option for players looking to bolster their arsenal.
Integrating the Finger Seal into your setup can significantly enhance your damage output. Buffs like Golden Vow improve both physical damage and defense, making you a formidable opponent in both PvE and PvP scenarios.
Here are some tips to help you excel with the Bleeding Claymore:
Timing is Key: Master the timing of your attacks, especially the multi-stab moves, to maximize bleed effects against bosses and tougher enemies.
Manage Stamina: The Claymore's heavy attacks can drain stamina quickly. Ensure you have enough stamina to evade or block after combos to avoid counterattacks.
Experiment with Infusions: While Quality Affinity is a strong choice, don’t hesitate to explore other options like Bleed or Heavy to find what best suits your style.
Utilize Buffs Wisely: Engage enemies with buffs active to enhance effectiveness. The synergy of physical damage and bleed can be overwhelming when properly supported.
The Bleeding Claymore in the Elden Ring DLC is not just a weapon; it’s a versatile tool that adapts to various playstyles. With its potent bleed capabilities, strong scaling, and compatibility with powerful buffs, players can craft builds that excel in both PvE and PvP. By mastering the Claymore and its associated gear, you'll be well-equipped to tackle the challenges that await in the Lands Between. Delve deeper into the Elden Ring using high-quality Elden Ring runes from https://www.mmoexp.com/Elden-ring/Runes.html.
