In the extraction shooter landscape of ARC Raiders, few weapons carry the sheer squad-wiping authority of the Equalizer. As a legendary weapon specifically engineered to dismantle heavy robotic threats like Queens and Matriarchs, it is a highly coveted asset for high-tier raiding. However, you can’t simply purchase this weapon from an end-game vendor. To wield its raw power, you must first secure its blueprint, survive the extraction, and gather some of the rarest crafting components in the game.
Whether you are aiming to solo the game's toughest content or trying to speed up your squad’s farming efficiency, here is the exact breakdown of how to get the Equalizer blueprint, alongside an analysis of the math and materials required to actually build it.
Method 1: Surviving the Harvester Event Puzzle (Best & Highest Probability)
The most reliable way to secure the Equalizer blueprint is by entering a Harvester Event. This is a rotating map condition that spawns a massive ARC structure onto the active battlefield, typically guarded by an aggressive Queen boss patrolling the perimeter outside. On maps like the Dam Battlegrounds, the Harvester reliably touches down near the Red Legs landmark.
Completing the internal puzzle yields an incredibly high drop rate for legendary schematics, though it requires meticulous execution under intense environmental pressure.
1. Breach and Retrieve the Fuel Canisters
Once you sneak past the Queen and pry open one of the lower-level shutter doors, the Harvester's defense grid initializes. Your first objective is to locate 3 pill-shaped battery cylinders (fuel cells). One canister is typically already lying on the ground level, but the remaining two must be found by rushing to the upper-deck walkways. Here, you will need to breach sealed wall panels and cabinets. Don't waste time fully searching standard loot piles—focus entirely on finding the steel canisters and dropping them down to the lower deck.
2. Manage the Hazard Rotations
The Harvester runs on a brutal, automatic defense cycle that triggers roughly every 45 seconds. You must monitor the central core's light cues to survive:
Blue/Green Glow: This signals an impending EMP shockwave. While it will completely strip your shields, it is non-lethal. You can stay inside and keep working through it.
Orange/Yellow Glow: This indicates a catastrophic thermal purge. Three loud alarm blares will echo through the structure. When you hear this, you have only seconds to sprint out of the main structure through the ground vents or top auxiliary hatches. Failing to exit will result in being instantly burned alive.
3. Load the Core and Disable the Alarms
When the interior clears of fire, rush back to the lower deck, pry open the hatches around the central terminal console, and slot all 3 canisters into their receptacles.
Once the final canister is locked in, a localized countdown timer starts, and flashing yellow alarm nodes will pop out from the walls and balconies around the room. You must immediately shoot or melee every single yellow node. If you fail to destroy all of them before the timer hits zero, the Harvester resets: the fuel cells will be violently ejected from the terminal, forcing you to load them back in and try again (though your progress on previously destroyed nodes carries over).
4. Collect the Ultimate Payoff
The moment the final yellow node shatters, the hazard loops deactivate permanently. Three major loot pods will lower from the ceiling in the center of the terminal. Opening these containers rewards you with high-tier ARC components and offers a massive chance at pulling either the legendary Jupiter or the Equalizer blueprint.
Method 2: Defeating the Queen Spaceport Raid Boss (The Hard Route)
If you prefer direct combat over puzzle-solving, the blueprint can also drop dynamically from the Queen herself. This route is significantly harder and demands an immense amount of heavy ammunition and precise positioning.
When a Queen is destroyed, she drops a large, interactable sphere known as the Queen Core. Cracking open this core offers a low-to-medium chance of dropping the Equalizer blueprint as a raw reward. Because of the high risk of being third-partied by rival squads while fighting a boss in the open, most seasoned players use the Harvester puzzle to lock down the schematic first, saving the Queen fights for gathering the actual crafting components.
For players looking to skip the intense mechanical grind of these events entirely, alternative out-of-game options exist. Platforms like U4N offer digital trading markets where you can find an arc raiders schematics for sale pc, allowing you to buy the blueprint directly from other players who securely drop the item into your safe pocket during an in-game custom session.
By the Numbers: Crafting the Equalizer
Securing the blueprint is only 50% of the journey. Once the schematic is safely resting in your permanent inventory, you must upgrade your base Refiner and venture back into high-risk zones to collect the necessary manufacturing assets.
To craft a single Equalizer, you need to compile the following itemized bill of materials:
Required Material Quantity Primary Acquisition Method Optimal Farming Strategy
Queen Reactor 1 Dropped by destroying the Queen raid boss, or by breaking her leg armor. Use an Anvil Splitter to focus fire on her leg plates; they will pop off mid-battle, allowing you to scoop up the reactor and extract early without killing the entire boss.
Magnetic Accelerator 3 Found in high-tier military zones or dropped from Queen variants. Loot the red lockers located inside the Rocket Assembly sector on the Spaceport map. Alternatively, craft them at Refiner Level 3 using standard Motors and Bombardier Cells.
Complex Gun Parts 3 Found in high-security military supply crates or traded via NPCs. Farm the Lobby area within Stella Montis or clear out the Control Tower on the Dam Battlegrounds map. Can also be traded with Celeste in exchange for Seeds.
The Exponential Payoff
While a investment of 1 Queen Reactor, 3 Magnetic Accelerators, and 3 Complex Gun Parts represents hours of high-stakes extraction gameplay, the statistical return on investment is unparalleled.
Prior to unlocking the Equalizer, breaking a single piece of a Queen’s armored leg plating can easily consume multiple magazines of standard kinetic or plasma ammunition. However, the Equalizer features a specialized structural damage profile. Data from field runs shows that the Equalizer tears through heavy armor plates roughly 3 to 4 times faster than mid-tier weaponry.
Once your first Equalizer is successfully assembled, subsequent runs to farm additional Queen or Matriarch reactors become trivial. A squad equipped with even a single Equalizer can reliably break armor plates, gather rare materials, and successfully initiate extraction in under 6 minutes, completely shifting the power dynamic of the wasteland in your favor.
