oggi mi è successo che non funziona più il finestrino SX anteriore, e all'estrazione della chiave le porte non si aprono, devo premere io il bottone, ho fatto una diagnosi con il VAG e ho riscontrato i seguenti errori, che sono?
Wednesday,23,January,2013,18:37:09:37412
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ7Y080512 Mileage: 109650km/68133miles
Address 01: Engine Labels: Redir Fail!
Part No: 045 906 019 CA
Component: 1,4l R3 EDC 0400SG 8400
Coding: 00002
Shop #: WSC 00788
VCID: 56A9F7FC9897
WVWZZZ9NZ7Y080512 VWZ7Z0F4446786
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Part No SW: 6Q0 907 379 AS HW: 6Q0 907 379 AS
Component: ESP 8.0 front H05 0003
Revision: 00000000 Serial number: 00000000000000
Coding: 0002368
Shop #: WSC 00788 785 00200
VCID: 8E195F9CE0C7
Address 08: Auto HVAC Labels: None
Part No: 6Q0 907 044 E
Component: CLIMAtronic PQ24 3805
Shop #: WSC 00000 000 00000
VCID: 346D6D742EAB
1 Fault Found:
01273 - Fresh Air Blower (V2)
000 - - - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 00BP BN-SG. 1S34
Coding: 09358
Shop #: WSC 00788
VCID: 3C7D455406FB
1 Fault Found:
00969 - Fuse for Heated Rear Window (S41)
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 18 AIRBAG VW51 0P 0009
Coding: 12600
Shop #: WSC 00788
VCID: 2C5D7514F69B
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 804 K
Component: KOMBIINSTRUMENT VDO V03
Coding: 01132
Shop #: WSC 00000
VCID: 39735C4009C9
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 01K1 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 00788
VCID: F0E521649A33
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER VDO V03
Coding: 01132
Shop #: WSC 00000
VCID: 39735C4009C9
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10150
Shop #: WSC 00788
VCID: 6FE7A218070D
Address 45: Inter. Monitor Labels: None
Part No: 6Q0 951 171 C
Component: Innenraumueberw. 0020
VCID: 32616B6CD4BF
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 64 Komfortgerát 0002
Coding: 00019
Shop #: WSC 00788
VCID: 3D7B48501DE1
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-00 - Unknown Switch Condition
