spia abs
Inviato: martedì 8 maggio 2012, 18:59
Ciao a tutti sono disperato...
allora spia abs un giorno accesa, due no.
pensavo bah si sarà sbagliato la macchina
invece ora è fissa ho fatto la diagnosi con il vag com:
VAG-COM Version: Release 311.2-N
Chassis Type: 9N1 - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 036 906 034 DD
Component: MARELLI 4MV 4963
Coding: 00071
Shop #: WSC 31414
WVWZZZ9NZ3D158661 VWZ7Z0C6680717
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 31414
2 Faults Found:
01276 - ABS Hydraulic Pump (V64)
014 - Defective - Intermittent
012 - Electrical Fault in Circuit
Address 08 -------------------------------------------------------
Controller: 6Q0 820 045
Component: Klimaanlage X0840
1 Fault Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to B+
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 25742
Shop #: WSC 31414
4 Faults Found:
00969 - Fuse for Heated Rear Window (S41)
37-10 - Faulty - Intermittent
00966 - Fuse for Blinkers (S151)
00900 - Fuse for Signal Horn (S194)
00906 - Horn (H1)
28-10 - Short to B+ - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Q0 920 820
Component: KOMBI+WEGFAHRSP VDO V16
Coding: 01141
Shop #: WSC 00000
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 09 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 31414
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 R
Component: LenkhilfeKYO V913
Coding: 10140
Shop #: WSC 31414
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 4P Komfortgerát 0002
Coding: 00067
Shop #: WSC 31414
End -------------------------------------------------------
Leggendo nel forum ho controllato i fusibili nella batteria, e oggi ho smontato i sensori e puliti ma niente.
come faccio a vedere se i sensori sono buoni?
ma il vag me lo dovrebbe specificare se fosse il sensore?
grazie infinitamente per il vostro aiuto
polo 9n 2003
1.4 benz 75cv
...invece ora è fissa ho fatto la diagnosi con il vag com:
Coding: 00071
Shop #: WSC 31414
Coding: 0001097
Shop #: WSC 31414
2 Faults Found:
1 Fault Found:
Coding: 25742
Shop #: WSC 31414
4 Faults Found:
00906 - Horn (H1)
Coding: 01141
Shop #: WSC 00000
Coding: 00014
Shop #: WSC 31414
Coding: 10140
Shop #: WSC 31414
Coding: 00067
Shop #: WSC 31414
polo 9n 2003
1.4 benz 75cv
